おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Check out our new arrivals!
reComputer Jetson-10-1-H0 built with Jetson Nano Production Module, reComputer Jetson-20 built with Jetson Xavier NX Production Module also includes on-device carrier board and heatsink.
  • Back-illuminated Time-of-Flight (ToF) image sensor
  • High signal to noise ratio (SNR)
  • Full resolution @max60 fps (4phase/frame)
  • Pixel binning readout function
  • Independent flipping and mirroring
  • Built-in temperature sensor
This is a world-leading ToF module with high precision, VGA high resolution, wide-angle, compact, and easy to use.
The IMX556 is a fully integrated optical Time-of-Flight (ToF) camera sensor. The sensor features 640 x 480 (VGA) time-of-flight pixels based on the DepthSense® pixel technology. This DepthEye Wide camera provides a 100-degree view in the horizontal direction, and the detection range is 0.3m ~ 2.5m.
Specifications
SpecificationDetails
SensorSony IMX556PLR CMOS
Pixel Size10.0 μm (H) × 10.0 μm (V)
Resolution/FPS0.3MP 640 x 480 px/ Max 30 FPS
Dimension & Weight58 x 58 x 52 mm / 305 g
AccuracyLess than 1cm at 1.5m
PrecisionStandard deviation less than 3mm at 1m
Working Range0.3m up to 2.5m
FOVH100° x V75°
Data InterfaceUSB 3.1 Gen1 /Type C
Power Consumption12V / 1A (Peak) /0.5A(Average)
Illumination4 x VCSEL laser diodes @ 850nm
Operating Temperature-10 to +60 ̊C
Platform SupportWindows/Linux/Mac/Ros
SDK Language SupportC++/Python
  • 1 x DepthEye Wide
  • 1 x Type-C cable
  • 1 x 12V Power Cable
ドキュメント
認証
HSCODE8525801390
USHSCODE8525895050
UPC
EUHSCODE8517600000
COOCHINA
DepthEye Wide - H100° x V75° VGA ToF Camera with Sony IMX556PLR DepthSense™
SKU 114992563
heatsink.
USD$599.00
廃番
product.detail.alsoAdd.title
