製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Superior Image Quality: 2MP full HD resolution (1920×1080) with 30FPS transmission speed in MJPG format, paired with 1000mV/Lux-sec sensitivity and 60dB dynamic range, ensuring vivid, detailed images even in varying light conditions.
  • Ultra-Wide Viewing Angle: 90° or 120° diagonal FOV enables comprehensive coverage, eliminating blind spots and perfect for scenarios requiring a broad perspective.
  • Plug-and-Play Convenience: Complies with UVC international standard, supporting driver-free installation on Windows 7/10/11 and Linux 2.6.20+ systems for immediate use.
  • Robust & Reliable Design: Adopts SMT (ROHS) manufacturing process with a gold-plated and matte blue PCB. Features sealed construction with uniform adhesive application, ensuring dustproof and stable performance; withstands extreme temperatures from -20°C to 60°C.
  • Flexible Focus Control: Manual focus design allows precise adjustment for object distances ranging from close-up to infinity, adapting to different shooting requirements.
  • Strict Quality Assurance: Undergoes rigorous inspections for image performance, appearance, and mechanical strength; meets A-class quality standards with no visible defects, ensuring long-term durability.
仕様
ET-S231-90°
ET-S231-120°
FOV
90°
120°
Sensor Type
1/2.7-inch Color CMOS
Maximum Resolution
1920×1080 (2MP)
Pixel Size
3µm × 3µm
Frame Rate
30FPS (MJPG at 1920×1080), adjustable for lower resolutions
Module Size
32mm × 32mm
Interface
USB 2.0
Power Supply
USB Bus Power (5V)
Working Current
<180mA
Standby Current:
<10mA
Working Temperature
-20°C to 60°C
Output Formats
MJPG: 1920×1080, 1280×720, 800×600, 640×480, 608×1024 (30FPS)YUY2: 1920×1080 (10FPS), 1280×720 (20FPS), 800×600/640×480 (30FPS)
ハードウェア概要
認証
HSCODE8525891900
USHSCODE8525895050
UPC
EUHSCODE8517600000
COOCHINA
部品リスト
ET-S231 Camera
x1
Connection Cable 1.5m
x1
ET-S231 Megapixel 120° Wide-Angle 1080P USB Camera Module
SKU 100062162
The ET-S231 is a high-performance USB camera module engineered by Shenzhen Rongyangseheng Electronic Technology Co., Ltd. Equipped with a 1/2.7-inch color CMOS sensor, it delivers crisp 2MP (1920×1080) video at 30FPS, ensuring smooth and clear image transmission for diverse application scenarios. Boasting a 90° or 120° diagonal wide-angle field of view, this module captures a broader visual range without distortion, making it ideal for video conferencing, surveillance systems, smart home devices, industrial inspection, and other professional or daily use cases. With UVC driver-free compatibility and support for multiple operating systems, it offers plug-and-play convenience while meeting strict ROHS environmental standards. Its robust construction, precise craftsmanship, and reliable performance under extreme temperatures further enhance its suitability for both indoor and outdoor applications.
JPY¥10130.00
