おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
The Grove - SCD41 is a compact yet powerful 3-in-1 environmental sensor for CO2, Humidity and Temperature measurement. Based on Sensirion SCD41, the photoacoustic NDIR sensor technology enables high accuracy and wide measurement range. Its miniture size, large supply voltage, high robustness and adjustable power consumption allow it to perfectly integrate into a variety of environmental monitoring applications such as Smart Ventilation System.
  • Photoacoustic NDIR sensor technology PASens®:Embedded Sensirion SCD41 enables real-time CO2 detection with a high accuracy of up to ±(40 ppm + 5 %)  and a wide measurement range of 400 to 5,000 ppm
  • 3-in-1 environmental sensor: Integrated humidity and temperature sensor comes with algorithm that enables superior on-chip signal compensation and addition RH and T outputs
  • Compact size: the smallest form factor of 10.1 x 10.1 x 6.5 mm3 allows space-effective integration
  • Fit for various applications base on uses' need: Supports large supply voltage of 2.4 V – 5.5 V, robustness towards external stresses and the adjustable power consumption down to < 0.4 mA avg
CO2 is a key indicator for indoor air quality as high levels compromise humans’ cognitive low power and well-being. The Grove - CO2 & Temperature & Humidity Sensor - SCD41 enables smart ventilation systems to regulate ventilation in the most energy-efficient and human-friendly way. Moreover, indoor air quality monitors and other connected devices based on the SCD41 can help maintain low CO2 concentrations and comfortable Temperature & Humidity for a healthy, productive environment.
We've released the Seeed Gas Sensor Selection Guide and the Grove Selection Guide, it will help you choose the Grove that best suits your needs.
This product is Grove - CO2 & Temperature & Humidity Sensor for Arduino (SCD30) - 3-in-1 lighter version. The SCD41 packs are cheaper and lighter.
What is Grove?
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfil various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you with guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
Application
  • Air Purifier
  • Environmental Monitoring
  • Plant Environmental Monitoring System
  • Arduino weather station
Upgrade to Industrial Solutions
Get Started with Industrial Sensors
SenseCAP S210x series industrial sensors provide an out-of-box experience for environmental sensing. Please refer to the S2103 Wireless CO2, Temperature, and Humidity Sensor with higher performance and robustness for air quality monitoring.
With the SenseCAP S2110 Grove converter  and S2100 data logger, you can easily turn the Grove into a LoRaWAN® sensor. Seeed not only helps you with prototyping but also offers you the possibility to expand your project with the SenseCAP series of robust industrial sensors.
ParameterValue
Input voltage3.3V / 5V
Operating range-10~+60℃; 0-100% r.H.; 400-5,000 ppm
I2C Address0x62
InterfaceI2C
Comparision of SCD30 & SCD41
Module No.PrecisionRangeLow Power TriggerSize
SCD30
± 30ppm +3%
400 - 10,000ppm×35 × 23 × 14 mm
SCD41± 40ppm +5% 400 - 5,000ppm√10.1 × 10.1 × 13 mm
What is PASens® Technology?
PASens® Technology is based on the photoacoustic sensing principle. The photoacoustic sensing principle allows extreme miniaturization of the CO2 sensor without compromising sensor performance due to the fact that the sensor sensitivity is independent of the optical cavity size. The reduced size and the smaller number of integrated components result in a highly price-efficient BOM structure. Thanks to the miniaturizing and economical BOM structure of these new CO2 sensors, the SCD4x will open up numerous possibilities for a whole new set of products and applications.
Click here to learn more about the measurement principle and key features of PASens® Technology.
Grove - CO2&Temperature & Humidity Sensor(SCD41)×1
認証
HSCODE9025800090
USHSCODE9025801000
UPC
EUHSCODE9013101000
COOCHINA
Grove - CO2 & Temperature & Humidity Sensor(SCD41)- photoacoustic NDIR technology, algorithms, ideal for Smart Ventilation System
SKU 101020952
Grove - CO2 & Temperature & Humidity Sensor - SCD30
USD$52.90
product.detail.alsoAdd.title
