おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Color Detection: Measures red, green, blue, and white light components.
  • I2C Interface: Easy integration with microcontrollers via I2C for data access.
  • Supply Voltage: Operates at 3.3V or 5V.
  • Synchronization: Can work with an external pulsed light source for accurate readings.
  • Compact Design: Small form factor for easy integration into various projects.
  • Low Power Consumption: Ideal for battery-operated devices.
仕様
Color Channels
Red, green, blue, and clear (white)
Supply Voltag
3.3V to 5V
Interface
I2C
Resolution
16-bit color data output
Operating Temperature Range
-40°C to +85°C
Current Consumption
200μA
Selectable maximum detection range
515.4, 1031, 2062, 4124, 8248, or 16 496 lux with highest sensitivity 0.007865 lux/step.
Detection Range
0-5cm
ハードウェア概要
用途
  1. Ambient Light Sensing: Adjusting display brightness based on surrounding light conditions.
  2. Color Recognition: Identifying and classifying colors in objects for robotics or automation.
  3. Smart Home Devices: Integrating into lighting systems for color matching and ambient adjustments.
  4. Photography Equipment: Providing accurate color temperature readings for cameras.
  5. Wearable Technology: Monitoring environmental light levels for fitness or health tracking.
  6. Selectable maximum detection range:4, 1031, 2062, 4124, 8248, or 16 496 lux with highest sensitivity 0.007865 lux/step.
認証
HSCODE9031900090
USHSCODE9031902100
UPC
EUHSCODE9013101000
COOCHINA
部品リスト
Grove - Color Sensor V3.0
x1
Grove - Cable
x1
Grove - Color Sensor V3.0 - I2C interface - VEML6040 based
SKU 101021133
It is a sensor to measure the color chromaticity of ambient light or the color of objects. With the synchronization input pin, an external pulsed light source can provide precise synchronous conversion control.
USD$3.90
product.detail.alsoAdd.title
