おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
The Grove - I2C Color Sensor V2 can recognize different colors and then drive the lamp lighting in blue, green, yellow, orange and red accordingly
  • Recognize different colors: Enables accurate color and light sensing measurements under varying lighting conditions
  • Maskable interrupt: Programmable interrupt function with User-Defined Upper and lower threshold settings
  • Low power - 2.5μA sleep state: Enabling a low-power wait-state between RGBC measurements to reduce average power consumption
  • Digital output: 16-Bit digital output with I2C at 400 kHz
  • Grove unified socket: The product ensures "Plug and Play" and could be versatile for various applications of Grove
This is an updated version of the Grove - I2C Color Sensor module. The new version is based on the color sensor TCS34725FN with digital output I2C. We also changed the circuit's layout based on the new sensor. Based on the 3*4 array of filtered photodiodes and 16-bits analog-to-digital converters, you can gain the color chromaticity of ambient light or the color of objects. Of the 16 photodiodes, 4 have red filters, 4 have green filters, 4 have blue filters and 4 have no filter(clear). With the synchronization input pin, external pulsed light source can provides precise synchronous conversion control.
This module can be used to detect the color of light source or the color of objects. When used to detect the color of the light source, the led switch should be turned off, and the light source should shine the sensor directly. When used to detect the color of things, the led should be on and you should put the object on the top of the enclosure closely. The theory of sensing the color of objects is Reflective Sensing Theory. Like the picture below.
What is Grove?
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfil various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you with guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
One More Thing
Applications
  • RGB LED backlight control
  • Light color temperature measurement
  • Ambient light sensing for display backlight control
  • Fluid and gas analysis
  • Product color verification and sorting
End Products and Market Segments
  • TVs, mobile handsets, tablets, computers, and monitors
  • Consumer and commercial printing
  • Medical and health fitness
  • Solid state lighting (SSL) and digital signage
  • Industrial automation
Specifications
Dimensions42mm x23mm x10mm
WeightG.W 11g
BatteryExclude
Supply Voltage3.3/5V
Operating temperature range-40℃ to 85℃
InterfaceI2C
Grove - I2C Color Sensor V21
Grove Cable1
認証
HSCODE9031900090
USHSCODE9031808085
UPC841454120193
EUHSCODE9013101000
COOCHINA
Grove - I2C Color Sensor V2:RGB LED Control
SKU 101020341
USD$8.50
product.detail.alsoAdd.title
