おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Grove - I2C High Accuracy Temperature and Humidity Sensor (SHT35) measures temperature and humidity with high accuracy ±1.5% RH and ±0.1°C, respectively. Based on Sensirion SHT3x-DIS sensor, it offers exceptional intelligence, reliability, and improved accuracy specifications compared to its predecessor. Enables easy integration into industrial automation, smart home systems, etc.
  • High accuracy: Support reliable measurement of RH and temp boasting typical accuracies of ±1.5% RH and ±0.1°C, respectively
  • Rapid data transmission:I2C Interface with communication speeds up to 1 MHz and two user selectable addresses
  • Streamlined performance: With a fully calibrated, linearized, and temperature-compensated digital output, eliminating delays and ensuring prompt data acquisition
  • Wide compatibility: Operates on a wide supply voltage range of 2.15 V to 5.5 V, making it compatible with a variety of assemblies.
  • Versatile connectivity: The Grove interface enables effortless "Plug and Play", while its adaptability makes it ideal for environment detection of applications
Grove - I2C High Accuracy Temperature and Humidity Sensor (SHT35) is based on SHT3x-DIS, relative to Sensirion's previous generation of temperature and humidity sensors. The new SHT3x-DIS temperature and humidity sensor have increased intelligence, reliability, and accuracy specifications. Simultaneously enhanced signal processing and provides users with two unique I2C addresses and communication speeds of up to 1 MHz. It also features an Alert Mode, which allows to monitor the environmental condition (humidity and temperature) relative to programmable limits. And Grove - I2C High Accuracy Temp&Humi Sensor (SHT35) supported Arduino and Raspberry Pi.
What is Grove?
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfil various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you with guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
Applications
  • Medical Use
  • Home/Outside Environment
  • Automobile
  • Food Processing
  • Industrial Freezers and Refrigerators
Upgrade to Industrial Solutions
Get Started with Industrial Sensors
SenseCAP S210x series industrial sensors provide an out-of-box experience for environmental sensing. Please refer to the S2101 Wireless Temperature and Humidity Sensor with higher performance and robustness for air temperature and humidity detection.
Pin Out
Here’s this demo to start your own Automatic Humidifier project!
All you need for this project:
Seeeduino V4.2
Grove - Water Atomization
4.3 LCD Cape for BeagleBone® Black - Touch Display
Grove - Barometer (High-Accuracy)
Seeed Studio Grove - I2C High Accuracy Temp&Humi Sensor (SHT35)
And connecting all the Grove to the Seeeduino then uploading codes to your board then testing it. It is very simple! You can find all the code and step with this link
Dimensions20mm x40mm x6mm
WeightG.W 3.1g
BatteryExclude
Operating Voltage3.3V / 5V
Specified Temperature Range-40°C to +125°C
Temperature Resolution0.01°C
Temperature Accuracy Tolerance±0.1 °C
Specified Humidity Range0%RH to +100%RH
Humidity Resolution0.01%RH
Humidity Accuracy Tolerance±1.5 %RH
InterfaceI2C
I2C Address0x45(default) / 0x44(optional)
Grove - I2C High Accuracy Temp&Humi Sensor(SHT35)1
Grove Cable1
認証
HSCODE9025900090
USHSCODE9025900600
UPC841454121220
EUHSCODE9013101000
COOCHINA
Grove - I2C High Accuracy Temp&Humi Sensor (SHT35), I2C, ±1.5% RH and ±0.1°C, ideal for Smart Home, Industrial Automation
SKU 101020592
This Grove - SHT35 is an I2C environmental sensor for temperature and humidity measurement with high accuracy ±1.5% RH and ±0.1°C, respectively. Based on Sensirion SHT3x-DIS sensor, it offers exceptional intelligence, reliability, and improved accuracy specifications compared to its predecessor. Enables easy integration into industrial automation, smart home systems, etc.
USD$13.95
product.detail.alsoAdd.title
