Tip
We've released the Seeed Gas Sensor Selection Guide, it will help you choose the gas sensor that best suits your needs.
GGC2330 is a general-purpose and high-performance gas module with electrochemical gas sensors. It uses three electrodes, an electrochemical gas sensor, and a high-performance microprocessor. By installing the different gas sensors, the module could detect relevant gas.
Grove - Oxygen Sensor Pro(GGC2330-O2) is an enhanced version of Grove - Oxygen Sensor(GG2020-O2), Compared to the Grove - Oxygen Sensor(GG2020-O2), It has a built-in temperature sensor to make temperature compensation, which can correct the measurement error caused by the temperature difference and make the measurement more accurate. On top of that, it is equipped with a high-performance microprocessor, which allows it to have digital output and analog voltage output capabilities at the same time, making the sensor easier to use and calibrate and shorten the development period.
| Item | Parameter |
| Target Gas | O2 |
| Resolution | 0.1%VOL |
| Measurement Range | 0-25%VOL |
| ReOperating Voltage | DC 5±0.1V DC |
| Operating Current | < 10 mA |
| Output | Output UART(TTL electrical Level, 3V)Analog voltage(refer to table 2 for sensor original amplifying signal) |
| Operating Conditions | -20~25℃/15~90%RH(no condensation) |
| Storage Conditions | -20~50℃/15~90%RH(no condensation) |
| Size | ø23.5mm*24.5mm |
| Life Expectancy | 2 years(in the air) |
GGC2330-O2 is a professional Oxygen Sensor, which is precalibrated with the built-in MCU and temperature sensor. It features low power consumption, good stability, high sensitivity, and long life.
