おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
A general-purpose LED module in Grove form factor, available in different colors. Support adjustable LED orientation and adjustable LED brightness.
  • Support different color LEDs: The LED is plugged into the LED holder rather than soldered on the board\
  • On-board potentiometer adjustment: Support brightness control and a higher range of input voltages
  • Easy to use: compatible with Grove port, just plug-and-play
  • High Flexibility: The ingenious PCB design enables you to bend the LED to any position you want, which makes it easy to use it standalone, horizontal, or on Panel Mount(from left to right)
Grove - Red LED is similar to the Grove - LED module which houses an LED light source. In addition, it also has a potentiometer on board to manage the power requirements of the LED. The PCB of this module has mounting holes which can be mounted on the required surface of your prototype. For example, it can be used as a pilot lamp for indicating power or signal presence. It's available in different colors:
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfill various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you with guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
ドキュメント
認証
HSCODE8531901000
USHSCODE8531809041
UPC841454107781
EUHSCODE8533210000
COOCHINA
技術詳細
Dimensions20mm x20mm x20mm
WeightG.W 9g
BatteryExclude
部品リスト
Grove - Red Led1
Grove - Red LED
SKU 104030005
USD$2.10
product.detail.alsoAdd.title
