おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • High accuracy and wide range of temperature and humidity measurements:
    - Humidity: 0 to 99.9 %RH with ±2% accuracy
    - Temperature: -40 to 80°C with an accuracy of ±0.5°C
  • Ultra-low power consumption: standby current supply as low as 40uA
  • Professional choice for relatively demanding applications: outperforms the basic DHT11
  • Better compatibility: digital output of sensor data, I²C interface makes it more versatile
  • Starter-friendly: Factory calibrated, easy to use, and backed by detailed wiki and documentation
    The DHT22 includes a capacitive humidity sensor and a high-precision temperature sensor. The range of humidity sensor is 0 to 99.9 %RH with ±2% accuracy while the temperature sensor ranges from -40 to 80℃ with ±0.5℃ accuracy. With the help of a built-in 8-bit microcontroller, the DHT22 converts the analog output of those two sensors to the digital signal, and outputs both temperature and humidity data via a single pin.
    Compared with the DHT11, this product has higher precision and a wider measurement range, but the usage and code are almost the same. Simply put, if you need higher measurement accuracy, this product will be a better choice; if you need a higher price/performance ratio, then Grove - Temperature & Humidity Sensor (DHT11) may be more appropriate. The table lists below the main differences between the DHT22, DHt20 and DHT11:
     DHT22DHT20DHT11
    Supply VoltageDC: 3.0 - 6.0VDC: 2.0 – 5.5VDC: 3.3 – 5.5V
    Measuring Range (Temperature)-40 ~ + 80 ℃-40 ~ + 80 ℃-20 ~ + 60 ℃
    Measuring Range (Humidity)0 ~ 100% RH0 ~ 100% RH5 ~ 95% RH
    Temperature Accuracy± 0.5 ℃± 0.5 ℃± 1 ℃
    Humidity Accuracy± 2 % RH ( 25 ℃ )± 3 % RH ( 25 ℃ )± 5 % RH ( 25 ℃ )
    Output SignalI2C signalI2C signal1-Wire
    DHT22 and DHT11 are both excellent temperatures and humidity sensors and they are widely used in Arduino and Raspberry Pi projects. However, from the comparison, the DHT22 outshines the DHT11 in every aspect from temperature range, temperature accuracy, humidity range to humidity accuracy. The only downside of the DHT22 is of course the slightly higher price but you are paying for the better specs.
    So if you want a sensor with a wider range and accuracy, go for the DHT22. If not, the DHT11 should work fine for your projects as well.
    All in all, DHT22 is an excellent low-cost temperature and humidity module, so we made this DHT22 breakout board with a Grove connector. Now it has even become more convenient to use. Just plug and play with your Seeeduino or Grove compatible shield. We have developed more than 400 Grove modules, covering a wide range of applications that can fulfill a variety of needs.
    Attention
    Since the DHT22 has been discontinued, this sensor will be EOL soon. We strongly recommend you use the upgraded DHT20 sensor, that is Grove - Temperature & Humidity Sensor V2.0 (DHT20)
仕様
Dimensions40mm x20mm x11mm
WeightG.W 11g
BatteryExclude
ハードウェア概要
用途
  • Environmental monitoring
  • Thermometer and hygrometer
  • Dehumidifier
認証
HSCODE9025900090
USHSCODE9025900600
UPC841454107521
EUHSCODE9013101000
COOCHINA
技術詳細
技術仕様
寸法40mm x20mm x11mm
重さG.W 11g
電池なし
部品リスト
パッケージ内容
Grove 温度および湿度センサPro – DHT22 / AM23021
Grove 温度および湿度センサPro – DHT22 / AM2302 - Grove Temperature & Humidity Sensor Pro
SKU 101020019
DHT22モジュール(AM2302またはRHT03とも呼ばれます)に基づいた高精度の温度および湿度センサーです。
JPY¥1101.00
product.detail.alsoAdd.title
