Product Details
Wiki & Learn
Reviews
Download PDF
The new Grove - Temperature & Humidity Sensor is based on the DHT20 sensor. The DHT20 is an upgraded version of the DHT11, compared with the previous version, the temperature and humidity measurement accuracy are higher, and the measurement range is larger. It features I2C output which means easier to use.
  • High Accuracy:
    • Temperature Accuracy:± 0.5 ℃
    • Humidity Accuracy:± 3 % RH ( 25 ℃ )
  • Wide measurement ranges:
    • Measuring Range (Humidity):0 ~ 100% RH
    • Measuring Range (Temperature):-40 ~ + 80 ℃
  • Better compatibility:
    • Digital output
    • I²C interface
  • Fully calibrated
  • Excellent long-term stability
  • Quick response and anti-interference capability
  • Wide voltage support 2.5-5.5V DC
Grove - DHT20 Temperature & Humidity Sensor is the newly released version, an upgraded version of the DHT11. It’s a high quality, low-cost digital temperature, and humidity sensor. DHT20 features a brand-new ASIC dedicated chip, an improved MEMS semiconductor capacitive humidity module, and a standard on-chip temperature element. Besides its performance, the efficiency of DHT20 has also improved over the previous generation, making it more cost-effective. Following the miniaturization and changes, the DHT20 is proven to be more robust in harsher conditions! DHT20 is also more versatile with its I2C signal which supports multiple masters!
With the wider and more precise range of measurement, the DHT20 will be more than suitable for various IoT uses, especially for cases such as precision farming and quality control! Each DHT20 sensor is factory calibrated and tested to ensure that it maintains its stable performance in the long-term for the years to come.
With its rigidity, reliability, and performance, the DHT20 is very suitable for HVAC, automobiles, data loggers, weather stations, home appliances, and even medical uses and other related temperature and humidity detection and controlled areas.
What is Grove?
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfil various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you with guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
Get Started with Industrial Sensors
SenseCAP S210x series industrial sensors provide an out-of-box experience for environmental sensing. Please refer to the S2101 Wireless Temperature and Humidity Sensor with higher performance and robustness for air temperature and humidity detection.
Applications
  • HVAC
  • Dehumidifier
  • Testing and Inspection
  • Equipment
  • Consumer Goods
  • Automobile
  • Automatic Control
  • Data Recorder
  • Weather Station
  • Home Appliance
  • Humidity Control
  • Medical Treatment
  • and other related temperature and humidity detection control project
Upgrade to Industrial Solutions
Comparison between DHT22, DHT20 and DHT11
 DHT22DHT20DHT11
Supply VoltageDC: 3.0 - 6.0VDC: 2.0 – 5.5VDC: 3.3 – 5.5V
Measuring Range (Temperature)-40 ~ + 80 ℃-40 ~ + 80 ℃-20 ~ + 60 ℃
Measuring Range (Humidity)0 ~ 100% RH0 ~ 100% RH5 ~ 95% RH
Temperature Accuracy± 0.5 ℃± 0.5 ℃± 1 ℃
Humidity Accuracy± 2 % RH ( 25 ℃ )± 3 % RH ( 25 ℃ )± 5 % RH ( 25 ℃ )
Output SignalI2C signalI2C signal1-Wire
Input Voltage2.0 – 5.5V
Measuring Humidity Range0 ~ 100% RH
Measuring Temperature Range-40 ~ + 80 ℃
Humidity Accuracy± 3 % RH ( 25 ℃ )
part list
Grove - Temperature & Humidity Sensor1
Grove Cable1
Certification
HSCODE9025800090
USHSCODE9025801000
UPC
EUHSCODE9013101000
COOCHINA
Grove - Temperature & Humidity Sensor V2.0 (DHT20) / Upgraded DHT11/ I2C Port
SKU 101020932
DHT11DHT22AHT20-Industrial Grade
JPY¥1029.00
