おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • On-board Lithium Battery Charging and Management Function,you could easily power your Seeed Studio XIAO with lithium 3.7V battery and recharge it
  • Grove connectors (Grove IIC*2, Grove UART*1), all 14 GPIO led out
  • Compact and Breakable Design
  • SPI-Flash Bonding Pad Reserved
  • On-board Power Switch and Charging Status Indicator Light
It acts as a bridge for Seeed Studio XIAO and Seeed's Grove system, which provides 300+ of different Grove modules including sensor, actuator, communication, display, etc. No more jumper wires and soldering work, you could enjoy creating more projects with Seeed Studio XIAO easily and quickly.
You could even break the board through the onboard PCB stamp holds according to your actual needs of the project (only 25*39mm in dimension after break-off), making it smaller than smaller.
Note
A pair of non-soldered 7-pin headers are accompanied in the product of Seeed Studio XIAO. You could solder them before connecting Seeed Studio XIAO with this Shield by plugging the soldered pin headers into the female headers on the Shield.
仕様
Parameters
values
Power Supply
5V / 3.7V Lithium Battery
Load Capacity
800mA
Charging current
400mA (Max)
Operating Temperature
- 40°C to 85°C
Storage Temperature
-55°C to 150°C
Grove Interface
Grove * 8 (IIC*2 / UART*1)
ハードウェア概要
  • Onboard
  • PinOut
Note Change Record
2025/12/30, PMIC Change from ETA ETA6003 to TI BQ24070
用途
  • Wearable devices
  • Rapid prototyping
  • Grove modules testing
  • Projects require small size
認証
HSCODE8517180050
USHSCODE8517180050
UPC841454123231
EUHSCODE8543709099
COOCHINA
部品リスト
Grove Shield for Seeed Studio XIAO
1
1*7pins male header
2
Note
This product does not include a Seeed Studio XIAO product, please click here if you need one.
Seeed Studio Grove Base for XIAO - with embedded battery management chip
SKU 103020312
Grove Shield for Seeed Studio XIAO is a plug-and-play Grove extension board for Seeed Studio XIAO series. With the on-board battery management chip and battery bonding pad, you could easily power your Seeed Studio XIAO with lithium battery and recharge it. 8 Grove connectors onboard includes two Grove IIC and one UART. It acts as a bridge for Seeed Studio XIAO and Seeed's Grove system. Flash SPI bonding pad allows you add Flash to Seeed Studio XIAO to expand its memory space, providing Seeed Studio XIAO with more possibilities.
USD$3.90
product.detail.alsoAdd.title
