製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
• This product is currently only certified by FCC. According to applicable laws and regulations, it is only available for sale in the United States.
This expansion board is currently not directly compatible with the XIAO nRF54L15 series because Arduino is not supported.
However, the hardware interface is fully compatible, and developers can manually adapt the software if needed.
Official software support from Seeed Studio is under development — stay tuned for updates!
The Wi-Fi Halow Board based on the FGH100M-H module is a high-performance, long-range Wi-Fi HaLow solution. Operating in the 902-928 MHz frequency band, it offers excellent penetration and coverage, making it ideal for smart home and IoT applications. With its compact design and compatibility with the Seeed Studio XIAO ecosystem, this card ensures reliable and efficient connectivity for various projects.
  • Long-Range Connectivity: Complies with IEEE 802.11ah standard, operating in 902-928 MHz frequency band, providing coverage up to 1 km with superior penetration performance.
  • Low Power Consumption: Optimized power efficiency design, making it ideal for power-sensitive IoT applications.
  • Robust Security: Implements comprehensive security features including AES, SHA-256, SHA-384, SHA-512, and WPA3 encryption.
  • Seamless Integration with Seeed Studio XIAO Boards: Sized at 42 x 25mm, it's compatible with the Seeed Studio XIAO Boards (Pre-Soldered) via easy snap-on. (We recommended to use XIAO ESP32 series.)
Note:
You may need to prepare additional antennas suitable for WiFi-HaLow use. Here are the verified, recommended antenna models 2.6dBi Long Range Antenna and SMA to I-PEX Antenna Cable.
仕様
Parameters
Details
WLAN Protocol
IEEE 802.11ah
Wi-Fi Frequency Band
902–928 MHz
Wi-Fi Antenna
1 x 1
Wi-Fi Modulation Mode
OFDM,BPSK, QPSK, 16QAM, 64QAM
Encryption Mode
AES, SHA-256, SHA-384, SHA-512, WPA3
Wi-Fi Operating Mode
STA
Operating Temperature Range
-30 °C to +85 °C
Extended Temperature Range
-40 °C to +85 °C
Physical Rate (Max.)
802.11ah: 32.5 Mbps
Power Supply Voltage
VBAT: 3.0–3.6 V, typ. 3.3 V
I/O Power Supply Voltage
VDD_IO: 1.62–3.6 V, typ. 1.8/3.3 V
FEM Power Supply Voltage
VDD_FEM: 3.0–5.25 V, typ. 5 V
用途
  • Smart Home Devices
  • Industrial Automation Control
  • Smart City Infrastructure
  • Agricultural IoT Monitoring
  • Environmental Monitoring Systems
認証
HSCODE8517799000
USHSCODE8517790000
UPC
EUHSCODE8517180000
COOCHINA
部品リスト
Wi-Fi HaLow Module
×1
Wi-Fi HaLow Transceiver for Seeed Studio XIAO
SKU 109100041
The Wi-Fi HaLow Board based on the FGH100M-H module is a high-performance, long-range Wi-Fi HaLow solution. Operating in the 902-928 MHz frequency band, it offers excellent penetration and coverage, making it ideal for smart home and IoT applications. With its compact design and compatibility with the Seeed Studio XIAO ecosystem, this card ensures reliable and efficient connectivity for various projects.
JPY¥2359.00
