製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Powered by XIAO nRF52840 Plus: Works immediately when connected to a compatible ePaper display, with onboard NFC interface for tap-to-configure, pairing, or triggering content updates.
  • Versatile Display Support: Compatible with a wide range of 24-pin ePaper displays, supporting 24-Pin epaper displays for various project requirements.
  • Extension IO Port: Enables connection of additional sensors, such as temperature and humidity sensors, for enhanced functionality.
  • BAT Connector with Switch: Provides simple battery connection and integrates a switch, enabling efficient power management and energy savings.
  • Compatible with Various Software Platforms: Whether you prefer coding with Arduino, Platform IO, ESPHome and more, this driver board both approaches, providing maximum flexibility for your projects.
仕様
Parameter
Processor
ePaper Connector
FPC 24 Pin 0.5mm
Battery Connector
JST 2.0mm
Switch
Battery Power ON/OFF
Power Supply
- 3.7V Li-Battery
- USB Type-C
Button
-1x Reset button
-3x User button
Software
Support Arduino/PlatformIO development platform
ハードウェア概要
用途
  • Smart Name Badge: Create battery-powered ePaper name tags for events or offices, updated via NFC tap or wireless connection, with buttons to switch profiles or display QR codes.
  • Dynamic Price Tags: Build low-power retail labels that show prices, stock levels, or promotions on differernt size ePaper, updated periodically without needing constant power.
  • Meeting Room Signage: Use as status boards for meeting rooms, showing booking info, occupant name, or “Do Not Disturb” states, with buttons to quickly change modes.
  • Portable Checklist Board: Make handheld task boards or packing lists that keep their content even when powered off.
ePaper Board Selection Guide
Product
Processor
XIAO
ESP32-S3 Plus
XIAO
nRF52840 Plus
XIAO
ESP32-S3 Plus
XIAO
nRF52840 Plus
XIAO ESP32-S3 Plus
XIAO ESP32-S3 Plus
N/A(Compatible with XIAO Series)
Compatible Displays
24 Pin ePaper
24 Pin ePaper
50 Pin ePaper
24 Pin ePaper
Battery Connector
JST 2.0mm
JST 2.0mm
JST 2.0mm
JST 2.0mm
JST 2.0mm
Button
1x Reset,
3x User
1x Reset,
3x User
1x Reset
3x User
1x Reset
3x User
Extension IO Port
SenseCraft HMI
認証
HSCODE8517629990
USHSCODE8543903500
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
XIAO ePaper Display Board EN05
×1
24Pin Adapter and 24Pin FFC Extension Cable
×1
XIAO ePaper Display Board(nRF52840) - EN05
SKU 100085486
Powered by the XIAO nRF52840 Plus, the display board EN05 supports a wide range of 24-pin ePaper displays. It features extension IO port for connecting additional sensors, JST 2.0 mm battery connector with power switch, built-in charging IC, and comes with three user buttons. Well-suited for ultra-low-power ePaper projects such as smart name badges, electronic price tags, meeting room signage, and portable information boards.
JPY¥1567.00
