Note:
This expansion board is currently not directly compatible with the XIAO nRF54L15 series because Arduino is not supported.
However, the hardware interface is fully compatible, and developers can manually adapt the software if needed.
Official software support from Seeed Studio is under development — stay tuned for updates!
What is RS-485?
RS-485 is an efficient and reliable serial communication standard, suitable for various applications that require long-distance and multipoint connectivity. Its noise immunity and flexibility have made it widely used in industrial and communication sectors.
How does RS-485 work?
RS-485 uses a pair of signal lines (A and B) to transmit data, providing excellent noise immunity and supporting half-duplex communication modes. It allows for the connection of up to 32 devices on the same bus, with each device having a unique address for identification in sending and receiving data. This standard is widely used in industrial automation, remote monitoring, and other applications, and when combined with the Modbus protocol, it facilitates efficient data exchange and management between devices.
With the Seeed Studio RS-485 Breakout Board, you can harness the powerful capabilities of the Seeed Studio XIAO development boards and their extensive ecosystem to create projects that require reliable high-speed long distance communication. Whether you are developing industrial control systems or IoT devices, this breakout board offers a reliable and compact solution to integrate RS-485 functionality into your projects.
Learn more about it here.
| Parameter | Specification |
| Product | Seeed Studio RS-485 Breakout Board |
| Compatibility | Seeed Studio XIAO development boards and Adafruit QT Py boards |
| Communication Interface | RS-485 |
| RS485 Chip | TP8485E-SR, half-duplex transceiver |
| Terminal Connection | 3-pin terminal for signal wire and 3-pin terminal for power |
| Communication Distance | Up to 1,200 m, depending on installation conditions |
| Transmission Speed | 250 kbps |
| TX/RX Indicators | LEDs indicate transmit and receive activity |
| Power Input | 5V or 12V DC; onboard 12V-to-5V conversion |
| Power Indicators | LEDs for the 5V and 12V inputs |
| Direction Control | Hardware automatic or software-controlled switching, selected by the 0 Ω resistor configuration |
Seeed Studio RS-485 Breakout Board | x1 |
The Seeed Studio RS-485 Breakout Board is a versatile RS-485 expansion designed for all Seeed Studio XIAO development boards. Equipped with the TP8485E transceiver IC, this breakout board efficiently converts UART serial streams to RS-485 signals. Operating in half-duplex mode, the TP8485E supports bidirectional RS-485 communication over distances of up to 1,200 meters. The board offers hardware automatic or software-controlled transmit/receive direction switching, configured through solder options. It accepts either a 5V or 12V DC power input and provides separate 3-pin terminals for power and RS-485 connections, making it suitable for reliable communication over long distances and in electrically noisy environments.
