製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
This expansion board is currently not directly compatible with the XIAO nRF54L15 series because Arduino is not supported.
However, the hardware interface is fully compatible, and developers can manually adapt the software if needed.
Official software support from Seeed Studio is under development — stay tuned for updates!
  • Tiny footprint: Fits neatly on all Seeed Studio XIAO microcontroller boards. With a small lithium-ion battery sandwiched between the dev board and its hat, the logger is well fitting for space limited projects.
  • Power supply enable: The GPIO-powered sensors allow almost a no-power sleep mode when the sensors are not used. The always-on RTC consumes less than 1 uA making it suitable for battery-powered data loggers.
  • I2C communication: Easy to program from existing libraries and supports adding more sensors on the same bus possible.
  • On-board RTC: The PCF8563 chip with its oscillator provides timekeeping, essential for long-term data loggers, and a programmable interrupt for deep sleep wakeups.
  • Accurate Monitoring: The SHT40 temperature sensor presents temperature readings with 0.2°C accuracy and humidity with 1.8%RH. The PCF8563 real-time clock has shown a 7 minute time shift over one year compared to 10 hours from the ESP32’s internal RTC.
  • Battery Voltage Monitoring: When connected with the lithium-ion battery, its status level can be safely monitored through a pin-enabled voltage divider.
A Community Design Scaled up by Fusion Co-Create
This cool creation is designed by Westlake University's Marcel. We're excited to work with him to bring this impactful design to the market via our Fusion Co-Create. It's a program where we applied the Fusion Prototype, Produce, and Promote services to scale up cool community projects, while the designers get a commission for each single piece sold.
Fully Open Source on GitHub
This product is fully open-sourced with schematics, layout, and Gerber files on GitHub, and Marcel will maintain all the firmware, software updates, and tech support over there too. We highly recommend you to follow the GitHub repo to stay updated.
[Github Repo]
仕様
Size
21 x 17.8 mm
Operating Temperature
-40°C to 85°C
Power Supply Range
2.4V ~ 3.6V
Current consumption
~ 500uA
Idle current consumption
~ 0.25uA
Communication Interface
I2C
● SHT40 Temperature & Humidity Sensor
● BH1750 Ambient Light Sensor
● PCF8563 Real-Time Clock
ADC
● Battery Voltage Read
SHT40 temperature & humidity sensor read time
~ 2ms
BH1750 ambient light sensor read time
~ 120ms
Compatible Hardware Platforms
● Seeed Studio XIAO
Battery
EEMB 3.7V Lithium Polymer Battery (500mAh)
Compatibility with Seeed Studio XIAO
While Marcel has only tested the Seeed Studio XIAO ESP32C3, ESP32C6, and ESP32S3 boards (by now) with the XIAO Logger Hat, other XIAO boards should also work based on the pin configurations. XIAO SAMD21 and RP2040 don't support battery charging and should not use battery monitoring. XIAO RP2350, ESP32C6, RA4M1, and MG24 support battery charging but need additional wiring. XIAO nRF52840, ESP32C3, and ESP32S3 fully support battery monitoring with a simple 2-pin header connection.
XIAO Boards
I2C
INT
ADC
EN
BAT
XIAO SAMD21
yes
yes
yes
yes
no
XIAO nRF52840 (Sense)
yes
yes
yes
yes
yes
XIAO RP2040
yes
yes
yes
yes
no
XIAO RP2350
yes
yes
yes
yes
yes but not aligned
XIAO ESP32C3
yes
yes
yes
yes
yes
XIAO ESP32S3 (Sense)
yes
yes
yes
yes
yes
XIAO ESP32C6
yes
yes
yes
yes
yes but not aligned
XIAO RA4M1
yes
yes
yes
yes
yes but not aligned
XIAO MG24 (Sense)
yes
yes
yes
yes
yes but not aligned
ハードウェア概要
用途
  • Real-time temperature and humidity monitoring
  • Connected home automation node
  • Low-power environmental data logger
  • Wearable devices
  • Programming and monitoring education
認証
HSCODE9025900090
USHSCODE8517180050
UPC
EUHSCODE9031808000
COOCHINA
部品リスト
XIAO Logger Hat board
x1
7-pin female header
x2
Note: Li-ion battery not included
XIAO Logger HAT - A tiny temperature, humidity and light add-on module for XIAO with RTC and battery voltage monitoring
SKU 114993446
This little hat add-on for XIAO incorporates a Sensirion SHT40 temperature and humidity sensor, the BH1750 ambient light sensor, a PCF8563 real-time clock for accurate timekeeping, and an enableable voltage divider to keep track of the battery voltage.This product is a co-create collaboration with Seeed Studio and Westlake University's Marcel.
JPY¥1265.00
