おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
This expansion board is currently not directly compatible with the XIAO nRF54L15 series because Arduino is not supported.
However, the hardware interface is fully compatible, and developers can manually adapt the software if needed.
Official software support from Seeed Studio is under development — stay tuned for updates!
  • Capacitive Touch Screen Expansion Board: Display with 1.28-inch round, 240×240 resolution, 65K colors, providing clear and colorful images exhibition
  • High Compatibility: Highly compatible with all XIAO series products, easily integrated into your current projects
  • Rich Peripheral: Feature onboard RTC, battery charge chip, TF card slot, JST 1.25 connector, all within its compact size
  • Watch-sized Design: Come with 39 mm circular design, suitable for wearable and space-limited projects
  • Plug and Play: All pins are led out, no soldering is needed
That is, you can have a reliable timekeeping, a way to extend memory up to 32GB FAT, a charging method by the lithium battery. With its mini size, the XIAO extension board is ideal for wearable and small-volume projects. It is a versatile and powerful extension board that can be used for a wide range of projects, from displaying sensor data to creating interactive interfaces.
仕様
Item
Detail
Power Supply
USB Type-C: 5V @35 mA
Battery Charge: 3.7V @37mA
Battery Connector
3.7V Li-ion Battery JST 1.25 connector
Charge current
~ 485 mA
RTC Battery Holder
CR927
RTC Chip
PCF8563
Expandable memory
TF Card Slot for up to 32GB FAT
Screen
1.28-inch touch screen
240×240 resolution
65K colors
Sample Rate
100Hz
Dimension
43mm x 43mm
ハードウェア概要
用途
Note
The 3D model of the shell for the Round Display can be printed by downloading the file below:
The 3D model diagram of the shell for Round Display
  • Programmable Touch Watch
  • Wearable Indicator
  • Visible Control Center
  • Gaming Devices
  • Interactive Displays
認証
HSCODE8543909000
USHSCODE8524911000
UPC
EUHSCODE8543709099
COOCHINA
部品リスト
Seeed Studio Round Display for XIAO
x1
A: Compared to others, the Seeed Round Display offers a unique circular form factor and higher modularity. While others have fixed MCUs, the Seeed board allows you to swap between different XIAO MCUs (ESP32-S3, C6, or nRF52840) while keeping the same display interface.
A: Its "best-in-class" status comes from its all-in-one integration. It’s not just a screen; it’s an expansion board with an onboard RTC, TF card slot, and Li-ion battery charging circuit. For DIYers, this means a "no-soldering" experience—just plug in a XIAO ESP32 and you have a complete, portable IoT device.
Round Display for Seeed Studio XIAO
SKU 104030087
This compact expansion board is designed for the Seeed Studio XIAO ESP32 series and features a 1.28-inch fully covered round touch display in a 39 mm disc form factor. It integrates an RTC holder, charging circuit, and TF card slot, making it well suited for interactive ESP32 projects such as smart home interfaces and wearables.
JPY¥2849.00
product.detail.alsoAdd.title
