おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Build Your Wi-Fi HaLow Network
Build your Wi-Fi HaLow network with the Wi-Fi HaLow Transceiver for Seeed Studio XIAO, Wio-WM6108 mini-PCIe Module, and HaLowLink 2 Gateway, connecting different device types through one access point. Get all three to start building and testing your complete Wi-Fi HaLow solution.
Note:
  • This product is currently only certified by FCC. According to applicable laws and regulations, it is only available for sale in the United States.
  • To ensure full functionality, the Wio-WM6108 Wi-Fi HaLow mini-PCIe Module requires the WM1302 Raspberry Pi Hat for proper integration. We recommend purchasing both together to guarantee seamless setup and optimal performance.
  • Wi-Fi HaLow is an open, standard Wi-Fi technology operating in the license-exempt Sub-1 GHz range.
  • You may need to prepare additional antennas suitable for WiFi-HaLow use. Here are the verified, recommended antenna models 2.6dBi Long Range Antenna and SMA to I-PEX Antenna Cable.
The Wio-WM6108 Wi-Fi HaLow Mini-PCIe Module,powered by the Quectel FGH100M-H, is a long-range, low-power Wi-Fi HaLow module. Operating in the 902-928 MHz frequency band, it offers excellent penetration and coverage, making it ideal for smart home and IoT applications. Featuring the industry-standard Mini-PCIe form factor, it's ideal for industrial and embedded applications where reliable connectivity and space efficiency are essential.
  • Long-Range Connectivity: Complies with IEEE 802.11ah standard, operating in 902-928 MHz frequency band, providing coverage up to 1 km with superior penetration performance.
  • Low Power Consumption: Optimized power efficiency design, making it ideal for power-sensitive IoT applications.
  • Large-Capacity Access: Supports up to hundreds of simultaneous device connections to the same Wi-Fi access point - ideal for large-scale IoT deployments.
  • Robust Security: Implements comprehensive security features including AES, SHA-256, SHA-384, SHA-512, and WPA3 encryption.
  • Mini-PCle Form Factor: Utilizing the industry-standard Mini-PCIe interface, this module enables straightforward integration into existing systems. The standardized form factor makes it an ideal choice for industrial and embedded applications, offering both reliable performance and installation convenience.
仕様
Parameters
Details
WLAN Protocol
IEEE 802.11ah
Wi-Fi Frequency Band
902–928 MHz
Wi-Fi Antenna
1 x 1
Wi-Fi Modulation Mode
OFDM,BPSK, QPSK, 16QAM, 64QAM
Encryption Mode
AES, SHA-256, SHA-384, SHA-512, WPA3
Wi-Fi Operating Mode
AP/ STA
Operating Temperature Range
-30 °C to +85 °C
Extended Temperature Range
-40 °C to +85 °C
Physical Rate (Max.)
802.11ah: 32.5 Mbps
Power Supply Voltage
VBAT: 3.0–3.6 V, typ. 3.3 V
I/O Power Supply Voltage
VDD_IO: 1.62–3.6 V, typ. 1.8/3.3 V
FEM Power Supply Voltage
VDD_FEM: 3.0–5.25 V, typ. 5 V
ハードウェア概要
用途
  • Smart Home Devices
  • Industrial Automation Control
  • Smart City Infrastructure
  • Agricultural IoT Monitoring
  • Environmental Monitoring Systems
認証
HSCODE8517799000
USHSCODE8517620090
UPC
EUHSCODE8517180000
COOCHINA
部品リスト
×1
Wio-WM6108 Wi-Fi HaLow mini-PCIe Module(SPI)
SKU 109990565
USD$14.90
product.detail.alsoAdd.title
