製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Built in XIAO ESP32-S3 Plus:Works immediately when connected to a compatible ePaper display.
  • Dedicated 13.3" Spectra™ 6 E-Ink Support: Specifically designed for 13.3" Spectra™ 6 displays, ensuring quick setup and stable operation.
  • BAT Connector with Switch: Provides simple battery connection and integrates a switch, enabling efficient power management and energy savings.
  • User-Friendly Buttons: Features 1 reset button and 3 user-programmable buttons, providing flexibility for project acceleration and customizable functions.
  • SenseCraft HMI Firmware Pre-Flashed: Simply plug in and start right away with SenseCraft HMI, our AI-powered no-code UI design platform. Choose from rich templates or drag-and-drop UI building (with optional AI assistance), and deploy to the ePaper display in just a few clicks.
Note:
Occasional high-frequency sound may occur during operation. This is normal due to the ePaper power circuit and does not affect performance.
仕様
Parameter
Processor
XIAO ESP32-S3 Plus
ePaper Connector
FPC 60 Pin 0.5mm
Battery Connector
JST 2.0mm
Switch
Battery Power ON/OFF
Power Supply
- 3.7V Li-Battery
- USB Type-C
Button
-1x Reset button
-3x User button
ハードウェア概要
用途
  • Real-Time Dashboard: Display live information such as weather updates, calendar schedules, key notifications, and data widgets like energy usage, sensor status, or KPIs.
  • Security Alerts: Display alerts and notifications about security events, such as motion detection or door/window sensor activation.
  • Digital Photo Frame: Create a WiFi-enabled digital photo frame that can display images from your local network or cloud albums.
  • Public Transit Arrival Board: Show real-time bus/train arrival times, route status, and service alerts at a glance for daily commuting.
ePaper Board Selection Guide
Product
Processor
XIAO
ESP32-S3 Plus
XIAO
nRF52840 Plus
XIAO
ESP32-S3 Plus
XIAO
nRF52840 Plus
XIAO ESP32-S3 Plus
XIAO ESP32-S3 Plus
N/A(Compatible with XIAO Series)
Compatible Displays
24 Pin ePaper
24 Pin ePaper
50 Pin ePaper
24 Pin ePaper
Battery Connector
JST 2.0mm
JST 2.0mm
JST 2.0mm
JST 2.0mm
JST 2.0mm
Button
1x Reset,
3x User
1x Reset,
3x User
1x Reset
3x User
1x Reset
3x User
Extension IO Port
SenseCraft HMI
認証
HSCODE8543909000
USHSCODE8543903500
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
XIAO ePaper Display Board EE02
×1
60Pin Adapter and 60Pin FFC Extension Cable
×1
2.4GHz FPC Antenna (2.9dBi)
×1
XIAO ePaper Display Board EE02 for 13.3" Spectra™ 6 E-Ink
SKU 100067144
Powered by XIAO ESP32-S3 Plus, the ePaper driver board EE02 supports 13.3" spectra™ 6 E-Ink. It features a JST 2.0 mm battery connector with power switch, built-in charging IC, and comes with one reset and three user buttons. Well-suited for low-power ePaper projects such as digital photo frames and information boards.
JPY¥2359.00
