Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Looking for more I/O pins and built-in battery charging? Check out the new XIAO RP2040 Plus for more possibilities in your next project!
  • Perfect Toolset for Learning Coding and Electronics
XIAO RP2040 offers an extensive development ecosystem that makes coding accessible for beginners while providing powerful tools for experienced developers. Code with Arduino IDE for rapid prototyping, utilize C/C++ SDK for optimal performance, explore MicroPython/CircuitPython for quick scripting, or develop with Rust and Go for modern applications. Backed by comprehensive documentation and an active Raspberry Pi community, you'll find abundant examples and resources to kickstart your projects. The board features both a 3-color User LED and an RGB LED, making it easy to add visual indicators or stunning light effects to enhance both functionality and creativity.
  • Classic Form Factor and Extensive Seeed Studio XIAO Ecosystem
Launched in 2021, XIAO RP2040 with the classic XIAO compact design of 21 x 17.8mm. Its native compatibility with the comprehensive XIAO Add-on ecosystem - from expansion boards, sensors and displays to connectivity modules and actuators (Grove Expansion, CAN-Bus, LoRa module, LED Matrix, Vision AI Sensor, Round Display, L76K GSP module, 2-Mic Array, ePaper Displays, mmWave sensor, AC relay, Bus Servo Driver and many more) - makes it versatile for any project, no matter how simple or complex.
  • Production-Ready Design with FREE PCBA Support
All Seeed Studio XIAO dev boards feature a production-optimized SMD (Surface Mount Device) design with standardized stamp holes, making it perfect for commercial PCBA (Printed Circuit Board Assembly) integration. With our Seeed Studio Fusion services, you can access competitive one-stop PCB fabrication, component sourcing, assembly, and testing, plus free DFA/DFM review to reduce manufacturing risks and accelerate the journey from prototype to production.
Note
XIAO SoM User Manual open-sources all hardware and software materials of XIAO, providing professional product design guidelines to help you accelerate ideas off the ground, streamline product design, providing a seamless experience from module selection to mass production. You can check here to see more info.
Product Name
Seeed Studio XIAO RP2040
Seeed Studio XIAO RP2350
Chipset
Raspberry Pi 2040
Raspberry Pi RP2350
Processor
Dual Cortex M0+ processor running at up to 133 MHz
Dual Cortex-M33 processor running at up to 150MHz with FPU
RAM
264KB SRAM
520KB SRAM
Flash
2MB Onboard Flash
2MB Onboard Flash
Interface
GPIO Pin x14
Digital Pin x11
Analog Pin x4
I2C x1
UART x1
SPI x1
PWM x11
GPIO Pinx22
Digital Pin x19
Analog Pin x3
I2C x2
UART x2
SPI x2
PWM x19
Onboard
User LED (3 Colors) x1
Power LED x1
RGB LED x1
Reset Button x1
Boot Button x1
User LED x1
Charge LED (Battery Charging Indicator) x1
RGB LED x1
Reset Button x1
Boot Button x1
Wireless Connectivity
Power
Input Voltage (Type-C): 5V
lnput Voltage (BAT): 5V
Low Power Mode(Typ.)
3.7V/27.9 mA
Software Compatibility
Arduino, PlatformIO, MicroPython, CircuitPython, tinyGo, Rust, Zephyr, and more to come
Arduino, PlatformIO, MicroPython, CircuitPython, and more to come
Working Temperature
-20°C-70°C
-20°C-70°C
Dimensions
21x17.8mm
21x17.8mm
Varients
XIAO RP2040 3PCS Pack
XIAO RP2040 (Pre-Soldered)
XIAO RP2350 (Un-Soldered)XIAO RP2350 (Pre-Soldered)
Hardware Overview
TOP
BOTTOM
PinOut
Application
  • Learning & Education - Arduino, MicroPython, CircuitPython, TinyGo, Rust, embedded systems basics
  • USB HID Devices - Custom keyboards, stream decks, arcade controllers, MIDI interfaces
  • Wearable Projects - Smart accessories, LED clothing, wrist devices, sensor wearables
  • IoT & Sensors - Environmental monitoring, smart home panels, weather stations, MQTT
  • Display Projects - LED matrices, POV displays, rotating LED spheres
  • Development - Rapid prototyping, hardware testing, PCB validation
  • Robotics - Basic motor control, sensor integration, automation
  • Audio/Video - Sound processing, media controls, visualizations
Certification
HSCODE8517180050
USHSCODE8517180050
UPC841454123521
EUHSCODE8543709099
COOCHINA
X1
7-Pin Header (2.54mm)
X2
SKU 102010428
XIAO RP2040 is a compact, Arduino-compatible dev board based on Raspberry Pi RP2040. As the smallest Raspberry Pi Pico board, it features a thumb-sized and surface-mount design. Thanks to its compatibility with multiple programming languages (C, Python, Go, Rust) and a wide range of available libraries, it's a cost-effective and user-friendly microcontroller for learning coding and electronics basics.
XIAO Dev Board
Pin Header
Package
JPY¥618.00
