Product Details
Wiki & Learn
Reviews
Download PDF
  • Average gain dBi: 3dBi
  • Frequency range: 860-930MHz
  • Length: 360mm
  • Robust enough to tolerate outdoor environment and water-proof
  • Compatible with SenseCAP M1 Indoor Gateway
  • Comes with an antenna base (no magnetic)
For some applications like in an urban environment or where large stretches of land have to be monitored the normal range of LoRa might not be enough. If you need to increase the range for your LoRa devices, then this outdoor LoRa Fiberglass antenna will be the ideal addition to your LoRa system. It’s a robust solution to provide extra power and range for outdoor LoRa Base stations. The antenna has an average gain of 3dBi, a length of 360mm, and a frequency range from 902-928MHz. It comes with an antenna base as well.
The Antenna has an N-type male connector, and it comes with an N-type Female to RP-SMA male base so it can be easily connected to the SenseCAP M1 Gateways, which has an RP-SMA female connector.
Frequency
860-930MHz
Impedance
50Ω
VSWR
≤2.5
Gain
≤3dBi±1.0
Efficiency
>60%
Beamwidth
360°
Connector
N-Type Male
Material
Fiberglass
Length
360mm±5mm
Operation Temperature
-30℃~65℃
Part list
3 dBi Antenna*1
Antenna Base*1
Certification
HSCODE8517710000
USHSCODE8517710000
UPC
EUHSCODE8471707000
COOCHINA
LoRa Fiberglass Antenna Kit with base; 860-930MHz-3dBi-360mm; RFELA-1/389
SKU 318020708
Fibreglass LoRa antenna with a gain of 3dBi, frequency range 860-930MHz, and 360mm length, comes with an antenna base, compatible with SenseCAP M1 Indoor Gateway. Designed for 860–930MHz and built with durability in mind, it’s the perfect match for the SenseCAP Solar Node P1 / P1 Pro, delivering enhanced performance for your Meshtastic or LoRaWAN setups.
US 5.8dBiUS 8dBi
JPY¥4733.00
