おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Active Stereo IR Employs active stereo IR technology for depth output, enabling accurate and reliable data output in various lighting conditions
  • Wide Sensing Range Provides quality depth data output from 0.15m to 10m
  • Wide FOV Provides wide field of view data at 91-degree horizontal and 66-degree vertical
  • Multi-camera synchrnoization Supports multi-camera synchronization for both depth image and RGB image
  • USB Connection Uses single USB 3.0 Type-C cable for power and connectivity
仕様
Product
Orbbec Gemini 2
Voltage
5V (USB Type-C)
Depth Technology
Active Stereo IR
Operating Temperature
0℃~40℃
Mechanical Dimension
90mm x 25mm x 30mm
Communication Interface
USB 3.0 Type-C
Camera Driver
UVC
Depth Range
0.15m ~ 10m
Ideal Range
0.2m ~ 5m
Depth Resoultion
Up to 1280x800 @ 30fps
RGB Resoultion
Up to 1920x1080 @ 30fps
Horizontal FOV
91°
Vertical FOV
66°
ハードウェア概要
ドキュメント
認証
HSCODE8525891900
USHSCODE8525895050
UPC
EUHSCODE8517600000
COOCHINA
部品リスト
Orbbec Gemini 2 3D Camera
x1
USB Type-C to Type-C
x1
SKU 101090144
The compact Gemini 2 3D camera is based on Active Stereo IR technology and is equipped with Orbbec’s latest custom ASIC for high quality depth processing, IMU, and single cable USB 3.0 power + connectivity. The wide FOV and the wide depth sensing range makes Gemini 2 adaptable for many applications, especially for robotics. It is easy to set up and operate with the Orbbec SDK and delivers extremely accurate and reliable data in various lighting conditions from pitch black to semi-outdoor.
USD$240.00
product.detail.alsoAdd.title
