おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Core Features
  • SLAMTEC AI Deep Learning Engine
  • Provides real-time indoor and outdoor 3D mapping and positioning capabilities
  • 6DOF Spatial Localization: Delivers high-precision real-time position and attitude data
  • End-to-End Stereo Depth Estimation: Generates dense depth data in real time
  • AI Object Recognition and Segmentation: Produces real-time object segmentation maps
  • Expandable LiDAR: Supports higher-precision 2D mapping
Supporting Software & Development Resources
  • Equipped with Aurora Remote UI customized interaction software for scene reconstruction and digital twin implementation
  • Comprehensive Aurora Remote SDK available, supporting C++, ROS1/ROS2, and Python
    • Enables rapid secondary development, custom application building, and accelerated downstream product deployment
Feature Overview
  • AI Deep Learning vSLAM Engine
  • Integrated design with compact form factor
  • Out-of-the-box functionality with no external dependencies
  • Indoor/outdoor versatility with strong environmental adaptability
仕様
Core Parameter
Specific Specification
Maximum Mapping Area
>1,000,000 m²
Relocalization
Supports global relocalization, accuracy ±5cm
Map Management
Supports map continuation, loading and saving
Mapping & Localization Mode
Primarily based on deep learning vSLAM, compatible with LiDAR fusion
Multi-Sensor Synchronization Mechanism
Hardware time synchronization
Camera Specification
Binocular fisheye, 60mm baseline, FOV 180°, global shutter, RGB
Camera Frame Rate
Typical 15Hz, 10/30Hz customizable
Dense Depth Camera Function
Adopts end-to-end deep learning solution; supports strong light & weak texture scenarios; effective detection rate >90%
AI Object Recognition & Segmentation
Supports 18 outdoor scenes and 80 indoor scenes; expandable and customizable on demand
Maximum Tilt Angle (when LiDAR is equipped)
No requirement (to ensure 2D mapping effect, it is recommended not to exceed 30° tilt angle)
2D Map Resolution (when LiDAR is equipped)
Adjustable: 2cm/5cm/10cm
LiDAR Measurement Distance (when LiDAR is equipped)
Maximum measurement distance: 40m @70% reflectivity
Power Consumption
10W (typical value, excluding LiDAR)
Operating Temperature
-20°C ~ 50°C
Startup Temperature
≥0°C
Storage Temperature
-20°C ~ 60°C
ハードウェア概要
No.
Category
Parameter/Description
1
Power Input
XT30PW-M
DC 9~24V
2
Power Input
USB Type-C
Supports USB PD3.0 protocol power input
3
Expansion Port
USB 3.1 Gen1
Supports OTG mode, compatible with Device/Host
4
I/O Port
SH1.0-6PWB
6-Pin external expansion port, used for LiDAR connection
5
Data Port
Ethernet RJ-45
Supports Gigabit Ethernet (1000BASE-T), full-duplex communication; default IP: 192.168.11.1
6
Operation Indicator
White LED
Used for device operation status indication
7
Status Indicator
Red/Green Bicolor LED
Used for device status indication
8
Reset Button
Press to power on; hold for 30 seconds to clear device configuration, then the device will restart automatically after configuration clearance
9
Storage Expansion
TF Card Slot
Supports TF card expansion, used for log storage
9
Storage Expansion
TF Card Slot
用途
認証
HSCODE9031499000
USHSCODE9031499000
UPC
EUHSCODE9013101000
COOCHINA
部品リスト
Aurors S A2M2
x1
Adapter
x1
Accessory Kit
x1
SLAMTEC Aurora S,Integrated Spatial Perception Module
SKU 100035718
The Slamtec Aurora S is a next-generation compact AI-integrated spatial perception system launched by SLAMTEC. Integrating visual perception, inertial navigation, and SLAMTEC's self-developed AI deep learning vSLAM technology, it features high integration and plug-and-play functionality. Suitable for high-precision 3D mapping, perception, and spatial positioning across multiple indoor and outdoor scenarios, it can be widely applied in fields such as embodied intelligence, industrial automation, digital twins, and low-speed autonomous driving.
Orbbec Gemini 336 Depth CameraOrbbec Gemini 2 3D CameraOrbbec Gemini 335LG 3D Camera
USD$800.00
廃番
product.detail.alsoAdd.title
