おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Feature
  • Easy Panel Mounting: The Panel Mount Kit for reTerminal DM enables easy installation of the device on a panel or enclosure with its easy-to-use mounting bracket and hardware.
  • Improved Accessibility: With the panel mount kit, the reTerminal DM can be easily accessed and operated from the front panel of a machine or device, making it more convenient and efficient to use.
  • Industrial-Grade Design: The kit features an industrial-grade design that makes it suitable for installation in a wide range of industrial settings and applications.
The Panel Mount Kit for reTerminal DM is a reliable and easy-to-use accessory that allows you to easily mount the reTerminal DM on a panel or enclosure. With its high-quality materials and secure fit, the kit provides improved accessibility and durability, making it ideal for use in rugged environments. The kit includes a mounting bracket and hardware for easy installation and allows for easy access to the reTerminal DM from the front panel of a machine or device. With the Panel Mount Kit for reTerminal DM, you can ensure that your device stays securely in place and is easily accessible for efficient operation.
Application
  • industrial scenario
Hardware Overview
M4 Screw
x4
M4 Nuts
x4
Panel Mounting – Clamp
x4
認証
HSCODE7326909000
USHSCODE7326908688
UPC
EUHSCODE7616991091
COOCHINA
Panel mount Kit for reTerminal DM
SKU 110061503
Din-Rail mount Kit
USD$4.00
product.detail.alsoAdd.title
