おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
This sliding block is functioning as a centering aid for mounting the guide profile in a 35 mm profile slot, designed for fixed equipment while performing the linear movement.
Feature
Design for Manufacture: Material for linear movement, centering aid for mounting the guide profile
Small and Lightweight: Suit for automatic equipment, industrial PLC like reRouter
This sliding block is functioning as a centering aid for mounting the guide profile in a 35 mm profile slot, designed for fixed equipment while performing linear movement, to maintain automatic equipment, PLC, and other industrial facilities performance.
The installation position of PLC should be far away from high-power electrical appliances, so as to help reduce the influence of electromagnetic interference. At the same time, the installation position can not have frequent vibration, and the device should be deployed with good ventilation, not at too high a temperature.
Inserting directly at the installation position is a really easy assembly and the screws are already in the pack.
Application
Hardware Overview
Sliding Block for Linear Guideway Rail
x1
Screws
x3
認証
HSCODE8538900000
USHSCODE8538901000
UPC
EUHSCODE8543709099
COOCHINA
Sliding Block for Linear Guideway Rail(screws included)
SKU 114070181
This sliding block is functioning as a centering aid for mounting the guide profile in a 35 mm profile slot, designed for fixed equipment while performing linear movement.
Panel mount Kit
JPY¥301.00
product.detail.alsoAdd.title
