製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Power Adapter provides stable power output and incorporates safety features such as overload and short circuit protection. Its compact and lightweight design makes it highly portable. With RoHS certification, it adheres to environmental standards. Suitable for a wide range of devices, it offers a dependable power solution that prioritizes safety and efficiency.
Feature
  • Stable Power Supply: Maintains a consistent output voltage within a specified range, even when the input voltage fluctuates or there are variations in the load.
  • Long Lifetime: Used for a minimum of 30,000 hours.
  • High Energy Efficiency: The average conversion efficiency reaches 86.2%.
  • Compact Form: The compact size makes it incredibly small and portable.
This power adapter for EU standard boasts a range of impressive features. With a wide input voltage and frequency range, it is suitable for global use. It delivers stable and efficient power, with a full load efficiency of at least 83% and an average efficiency reaching the Energy Star VI standard of 86.20%. The adapter provides reliable protection against overcurrent and short circuits, ensuring the safety of connected devices. With its long service life of at least 30,000 hours, this power adapter is a dependable choice for various applications.
Application
  • Personal Electronic Device
  • Home Appliances
  • Office Equipment
  • Industrial Equipment
Item
Min
Typ
Max
Input Characteristics
Input Voltage
Normal Input Voltage
100Vac
240Vac
Input Voltage Range
90Vac
264Vac
Input Frequency
Input Frequency Range
47Hz
50/60Hz
63Hz
Input Current
All Voltage Range & Output at Full Load
0.8A
Inrush Current
All Voltage Range & Cold Start at 25℃
30A
60A
Output Characteristics
Output Voltage
All Voltage Range at No Load
11.40Vdc
12Vdc
12.60Vdc
All Voltage Range at Full Load
11.40Vdc
12Vdc
12.60Vdc
Load Current
All Voltage Range at CC Mode
2A
Ripple and Noise
Measurement is done by 20MHz bandwidth oscilloscope
150mV
Hold-up Time
At Full Load & 115Vac/60Hz Input Turn Off at Worst Case
10ms
At Full Load & 230Vac/50Hz Input Turn Off at Worst Case
20ms
Turn-on Delay Time
At 100Vac to 240Vac Input & Full Load
3s
Energy Efficiency Characteristics
Standby Power
At 115Vac and 230Vac input voltage
0.1W
Average Efficiency
Normal input & output at 25%, 50%, 75%, 100% load
86.20%
Environmental Characteristics
Operating Temperature
Environmental temperature around the product normal work
-10℃
40℃
Storage Temperature
Storage temperature product doesn't work
-20℃
70℃
Operating Humidity
Environmental humidity around the product normal work
10%
90%
Storage Humidity
Storage humidity product doesn't work
5%
95%
Item
Acceptance criteria
Hi-pot test
Primary to Secondary: 4000Vdc / 5mAMax / 60 second (4400Vdc,3second for production)
No fire, smoke and other safety accidents
Insulation resistance
Primary to secondary add 500Vdc test voltage
≥50MΩ
Temperature rise
25℃ environment, rated voltage and load conditions, the temperature rise test shell surface
Skin temperature rise is less than 45℃
Burn-in
The power supply shall be burn-in for 2 Hours under normal input and 100% rated load at 40℃±5℃
The product does not appear abnormal
Lifetime
Reference standard MIL-HDBK-217F,full load at 25℃
30000 Hours min
ESD
Reference standard IEC61000-4-2 : Contact discharge:±4KV,Air discharge: ±8KV
Class A or B
Surge test
Reference standard IEC61000-4-5 : common mode(L-PE/N-PE)±2KV, differential mode(L-N) ±1KV
Class A or B
Audible noise
Quiet environment 30cm distance to the human ear hearing noise
Can’t hear the noise
Item
value
Safety, EMC & Environmental Directive Standard
RoHS
2011/65/EU (European Union)
CE
EN 62368-1:2014/A11:2017,
EN 55032:2015/A11:202x
Mechanical Characteristics
Dimension
69.3mm (L) x 41.45mm (W) x 26.7mm (H)
Weight
110.5g ± 10g
AC Plug
Lead-Free, Wall-Mount Type (European 2 Conductors)
DC Output Plug
5.5mm x 2.1mm x 10±0.3mm
DC Output Cable
Length = 1.5m, UL2725 22# (Certification Numbers: E315619/E341894/E336582/E318424)
Material Characteristics
Case Materials
PC UL94V-0
Power Adapter 12V 2A - EU
 X1
認証
HSCODE8504401400
USHSCODE8504406001
UPC
EUHSCODE8504400000
COOCHINA
Power Adapter, 12V/2A/24W, European Standard Plug, DC Output, 1.5m
SKU 110061506
This power adapter for EU standard boasts an average efficiency reaching the Energy Star VI standard of 86.20%. With its wide input voltage of 100V to 240V and frequency range long service life of at least 30,000 hours, this 1.5m power adapter is a dependable choice for various applications.
American Standard Plug
JPY¥1108.00
