製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
This power adapter for the American standard boasts an average efficiency reaching the Energy Star VI standard of 86.20%. With its wide input voltage of 100V to 240V and frequency range long service life of at least 50,000 hours, this 1.5m power adapter is a dependable choice for various applications.
Feature
  • Stable Power Supply: Maintains a consistent output voltage within a specified range, even when the input voltage fluctuates or there are variations in the load.
  • Long Lifetime: Used for a minimum of 50,000 hours.
  • High Energy Efficiency: The average conversion efficiency reaches 86.2%.
  • Compact Form: The compact size makes it incredibly small and portable.
This power adapter for the American standard boasts a range of impressive features. With a wide input voltage and frequency range, it is suitable for global use. It delivers stable and efficient power, with a full load efficiency of at least 83% and an average efficiency reaching the Energy Star VI standard of 86.20%. The adapter provides reliable protection against overcurrent and short circuits, ensuring the safety of connected devices. With its long service life of at least 50,000 hours, this power adapter is a dependable choice for various applications.
Application
  • Personal Electronic Device
  • Home Appliances
  • Office Equipment
  • Industrial Equipment
Categories
Item
Min
Max
Input Characteristics
Input Voltage and Frequency
Rated Input voltage
100V
240V
Reliable Input voltage
90V
264V
Rated Input Frequency
50Hz
60Hz
Reliable Input Frequency
47Hz
63Hz
Steady AC Current(at 100~240Vac input)
0.65A
Inrush Current(at AC 240V input, with cold staring)
60A
Standby(at 115 or 230Vac input)
0.1W
Full load Efficiency(at 115Vac or 230Vac input voltage, 100% load)
83%
Average Efficiency(at 115Vac or 230Vac input voltage)
86.20%
DC plug
5.5*2.1*10±0.3mm ,inside “+”,outside “-”
Output Characteristics
Rated Output Voltage(No load)
11.4V
12.6V
Rated Output Voltage(Full load)
11.4V
12.6V
Rated Output Current:
2A
Rated Power
24W
Categories
Item
Mechanical Requirement
Weight
117g±10g
Input plug type
Wall-mounted type. US-pin. 2 Conductors, <Live. Neutral>
Environmental Performances
Operating Temperature
0℃ to +40℃
Relative Humidity
10%RH to 90%RH
Safety and EMC Approval
UL FCC
Part List
Power Adapter 12V 2A - US
x1
認証
HSCODE8504401400
USHSCODE8504406001
UPC
EUHSCODE8504400000
COOCHINA
Power Adapter, 12V/2A/24W, American Standard Plug, DC Output, 1.5m
SKU 110061505
European Standard Plug
JPY¥1108.00
