おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Premium Connectors: Utilizes XT30 (2+2) connectors with gold-plated terminals to ensure reliable and stable power and signal transmission.
  • Durable Protection: The wire body is wrapped in a Φ10.0*320mm black braided mesh and Φ9.5*35mm black dual-wall tubing , reinforced with 704B black silicone at the joints.
  • Extreme Temperature Resistance: Built for harsh environments, supporting a wide operating temperature range from -60°C to +150°C.
  • Secure Connection: The terminals are strictly assembled according to the diagram with a pull force greater than 10N, preventing accidental disconnection.
仕様
Item
Product
BCCA4012-350MM Cable
Total Length
350 ± 15mm
Connector
XT30 (2+2)-F (2PCS)
Terminals
XT30 (2+2) Gold-plated (4PCS)
Power Wire
3239 16AWG (50/0.175TS) Red/Black
Signal Wire
3239 26AWG (7/0.155TS) Red/Black
Operating Temperature
-60°C to +150°C
Terminal Pull Force
> 10N
Sleeving
Φ10.0320mm Black braided mesh, Φ9.535mm dual-wall tube
Packaging
1 pc / PE bag
ハードウェア概要
認証
HSCODE8544422100
USHSCODE8544421000
UPC
EUHSCODE8544492000
COOCHINA
部品リスト
BCCA4012-350MM XT30(2+2) Cablex1
BCCA4012 XT30 (2+2) Dual Right-Angle 35CM Cable - For reBot Arm B601-DM
SKU 100079598
The BCCA4012-350MM is a custom power and communication cable. It is equipped with two XT30 (2+2)-F connectors featuring gold-plated terminals. The internal wiring consists of high-quality 3239 16AWG and 26AWG electronic wires. For superior durability, the exterior is protected by a 10.0*320mm black braided mesh and 9.5*35mm dual-wall tubing , enabling an extreme operating temperature range of -60°C to +150°C. Featuring a dual right-angle design with power on the right, it is an ideal wiring harness solution for robotics and compact automation applications.
USD$8.00
product.detail.alsoAdd.title
