おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Sub-millimeter Accuracy: Operates at an ideal range of 7 cm to 50 cm with minimum object detection down to <0.1 mm for defects and <1 mm for objects at 7 cm, making it perfect for high-precision tasks.
  • RGB via ISP: Uses an image signal processor (ISP) to enhance data from the depth sensors, allowing for perfectly matched RGB and depth data without the parallax errors associated with a dedicated RGB sensor.
  • Global Shutter: Equipped with global shutter sensors to capture high-speed movements without distortion, ensuring reliable performance in dynamic environments.
  • Small & Lightweight: At just 42 mm × 42 mm × 23 mm and 60 g, smaller than a golf ball, it is designed for tight integration into robotic arms and compact devices.
  • SDK 2.0 Support: Fully compatible with the cross-platform Intel RealSense SDK 2.0, supporting Windows, Linux, Android, and macOS with wrappers for Python, ROS, C/C++, and C#.
仕様
Voltage Range5V (USB Powered)
Operating Temperature0°C ~ 35°C (Ambient)
Mechanical Dimension42mm x 42mm x 23mm
Communication InterfaceUSB-C 3.1 Gen 1
Depth TechnologyStereoscopic
Image Sensor TechGlobal Shutter
Depth FOV87° x 58°
RGB FOV87° x 58° (ISP derived)
Depth ResolutionUp to 1280 x 720 (90fps)
RGB ResolutionUp to 1280 x 720 (30fps)
Ideal Range7cm to 50cm
IMUNo
用途
  • Medical & Healthcare (Wound Management)
The close-range accuracy allows for non-contact, complete 3D measurement of wounds in seconds, helping doctors track healing progress more effectively than traditional methods.
  • Manufacturing & Inspection
With defect detection accuracy as good as 0.1mm, the D405 enables automated quality control and high-precision pick and place for small objects.
  • Agriculture (Robotic Harvesting)
Provides accurate measurement and placement data, allowing robotic arms to gently pick fragile fruits and vegetables without damage.
  • Close-Range Robotics
Ideal for end-of-arm tooling where high-resolution depth and RGB data are required at very short distances for manipulation tasks.
ドキュメント
認証
HSCODE8525891900
USHSCODE8525895050
UPC
EUHSCODE8517600000
COOCHINA
部品リスト
RealSense Depth Camera D405x1
USB 3.0 Type-C Cablex1
Mini Tripodx1
SKU 100000540
The RealSense™ Depth Camera D405 is a short-range stereo camera providing sub-millimeter accuracy for your close-range computer vision needs. Operating at an ideal range of 7 cm to 50 cm, it features high-resolution global shutter sensors and utilizes an Image Signal Processor (ISP) to generate matched RGB data without a dedicated RGB sensor. This compact camera is optimized for precision robotics, medical imaging, and automated inspection.
USD$419.99
product.detail.alsoAdd.title
