製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Tailored for Software-Defined Radio & other RF applications, HF and 50MHz bands
  • No DC coupling - Minimum RF Input frequency (-3dB): 300kHz
  • Comes with two 16 bit ADCs 50 ohm inputs; 14-bit DACs 50 ohm outputs
  • Three times more performant dual-core ARM Cortex A9 + Xilinx Zynq 7020 FPGA for greater real-time processing capabilities
  • Hardware compatible with high-performance SDR (HPSDR)
  • Improved distortions, dynamic range, sensitivity, noise & crosstalk
The Red Pitaya SDRlab 122.88-16 Standard Kit contains the basic components to start developing high precision RF SDR applications with the Red Pitaya STEMLab 122.88-16 board. The board carries two 16-bit ADCs, 50-ohm inputs & 14-bit DACs with 50-ohm outputs, and features a powerful dual-core ARM® Cortex® A9 and Xilinx Zynq 7020 FPGA MCU. Clocked at 122.88 MHz, it is capable of ultra-low phase noise and has high hardware compatibility with high-performance SDR (HPSDR). It has also been rigorously tested for reduced distortions, noise & crosstalk, along with improved dynamic range & sensitivity, which will make it easy to build high-end RF applications.
Applications
  • SDR Transceivers
  • Radio Frequency Transmission
  • Software Amplifiers
  • RF Modulators / Demodulators
Specifications
SpecificationDetails
ProcessorDual-Core ARM Cortex-A9 MPCore
FPGAXilinx Zynq 7020
RAM512MB
System MemoryMicroSD up to 32GB
ConnectivityGigabit Ethernet
USB 2.0
WiFi (Dongle required, not included)
RF InputsChannels2
Sample Rate122.88MS/s
ADC Resolution16 bit
Full Scale Voltage Range± 0.25V / -2 dBm
Input CouplingAC
Bandwidth300 kHz - 500 MHz
Input Impedance50 Ω
RF OutputsChannels2
ADC Resolution14 bit
Full Scale Voltage Range± 0.5V / +4 dBm
Shortcut ProtectionN/A, RF Transformer & AC-coupled
Bandwidth300 kHz - 60 MHz
PeripheralsDigital IOs16
Analog Inputs4 Channels, 0-3.5V 12 bit
Analog Outputs4 Channels, 0-1.8V 12 bit
Communication InterfacesI2C, UART, SPI
Available Voltages+5V, +3.3V, -4V
SynchronizationTrigger input through extension connector
Daisy chain connection over SATA
  • 1 x Red Pitaya SDRlab 122-16 Standard kit
  • 1 x Micro-SD Card (16GB, class 10)
  • 1 x Micro-SD Card Adapter
  • 1 x Ethernet cable (1m)
  • 1 x International Power Adapter (5V, 2A)
ドキュメント
認証
HSCODE9023009000
USHSCODE9023000000
UPC
EUHSCODE9023001000
COOSLOVENIA
Red Pitaya SDRlab 122-16 Standard Kit for FPGA application
SKU 102060147
The SDRlab 122-16 Standard Kit is a kit for developing RF and software-defined radio applications with the Red Pitaya SDRlab 122-16 board. It comes with the basic accessories to get started, including the 122-16 board itself, a 16GB SD card, an ethernet cable and power supply.
JPY¥93065.00
廃番
