製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Flexible Development Opportunities: Explore limitless FPGA Applications like oscilloscopes, spectrum analyzers and more
  • Versatile Compute & FPGA with the STEMLAB125-14 Main Board
    • Dual-Core ARM Cortex-A9 MPCore
    • Xilinx Zynq 7010 FPGA
    • 512MB RAM, MicroSD Storage (Up to 32GB)
    • Ethernet, USB, WiFi (Dongle Required)
  • Complete Accessories for Getting Started:
    • 16GB, Class 10 SD Card
    • 1m Ethernet Cable
    • 5V2A Power Supply
    • 2x Oscilloscope Probes
    • 2x SMA to BNC Adapters
    • 2x 50 Ohm Termination
    • 2x SMA T Adapter
    • Logic Analyser PRO
    • WiFi Dongle
    • ALU Case
  • Ready for Deployment: CE, FCC Certified
The Red Pitaya STEMlab 125-14 Diagnostic Kit contains everything needed to start developing with the Red Pitaya STEMLab 125-14 board. The board features a dual-core ARM® Cortex® A9 and Xilinx Zynq 7010 FPGA MCU, offering both fast and slow analog I/O. The STEMLab 125-14 has 14-bit input/ output channels for highly accurate measurement results, and is suitable for use in professional environments such as industrial control systems or smart city controllers. It can be used as desired for various electronics applications as an oscilloscope, spectrum analyzer, LCR Meter, and more. In addition, you can explore free, open-source applications contributed by the community on the Red Pitaya Marketplace.
The STEMLab 125-14 Diagnostic Kit further extends the STEMlab 125-14 Starter Kit by including essential hardware like probes, adapters, the logic analyser PRO and the WiFi dongle. Now you can easily get your hands on the hardware required to build diagnostic applications with the STEMlab 125-14 board - all in a single package!
Applications
  • Oscilloscope
  • Industrial PID Controller
  • Signal Generator
  • Spectrum Analyser
  • Bode Analyser
  • LCR Meter
Specifications
SpecificationDetails
ProcessorDual-Core ARM Cortex-A9 MPCore
FPGAXilinx Zynq 7010
RAM512MB
System MemoryMicroSD up to 32GB
ConnectivityGigabit Ethernet
USB 2.0
WiFi (Dongle required, not included)
RF InputsChannels2
Sample Rate125MS/s
ADC Resolution14 bit
Full Scale Voltage Range± 1V / ± 20V
Input CouplingDC
BandwidthDC- 60MHz
Input Impedance1 MΩ
RF OutputsChannels2
Sample Rate125MS/s
Load Impedence50Ω
Shortcut ProtectionYes
Typical Raising / Falling Time2V / 10ns
BandwidthDC - 60MHz
PeripheralsDigital IOs16
Analog Inputs4 Channels, 0-3.5V 12 bit
Analog Outputs4 Channels, 0-1.8V 12 bit
Communication InterfacesI2C, UART, SPI
Available Voltages+5V, +3.3V, -4V
SynchronisationTrigger input through extension connector
Daisy chain connection over SATA
  • 1 x Red Pitaya STEMlab 125-14 board
  • 1 x Micro-SD card (16GB, class 10)
  • 1 x Micro-SD card adapter
  • 1 x Ethernet cable (1m)
  • 1 x International power adapter (5V, 2A)
  • 1 x ALU case
  • 1 x Logic analyzer PRO
  • 2 x Oscilloscope probes
  • 2 x SMA to BNC adapter
  • 2 x 50 ohm termination
  • 2 x SMA T adapter
  • 1 x WiFi dongle
ドキュメント
認証
HSCODE9023009000
USHSCODE9023000000
UPC
EUHSCODE9023001000
COOSLOVENIA
Red Pitaya STEMlab 125-14 Diagnostic Kit for FPGA application
SKU 102060146
The STEMlab 125-14 Diagnostic Kit is a comprehensive development kit for FPGA applications that includes everything you can find in the STEMlab 125-14 Starter Kit and additional adapters, probes and a WiFi dongle. It provides you with everything you need to create professional diagnostics applications, such as oscilloscopes, signal generators, spectrum analysers and more.
JPY¥80245.00
廃番
