Please complete required options
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
【Note】
  • From China warehouse to the United States, choose "US Direct Group Shipping" to enjoy duty-free!
  • 6 Degree-of- Freedom(DOF) Arm — Six STS3215 magnetic-encoder bus servos deliver 30 kg·cm torque per joint with 12-bit absolute position feedback for smooth, quiet, and repeatable motion
  • Hugging Face LeRobot Native Support — Works out of the box with the LeRobot framework for imitation learning; collect teleoperation data and train ACT/Diffusion models with community-shared pipelines.
  • Affordable & Flexible Kit Options — Low‑cost 3D‑printable robotic arm with flexible kit options. Select full‑assembly, servo‑only pack or unassembled parts to match your budget and project needs.
  • Fully Open-Source — All hardware designs, BOM, firmware, and software are publicly available; modify, extend, and share freely
One‑Stop Guided Setup & Cloud‑Powered Robot AI Training
SenseCraft Robotics is an in‑house developed, exclusive platform from Seeed Studio. It delivers an all‑in‑one robot‑AI workflow featuring guided setup, cloud training and lightweight local validation. It lets you finish essential pre‑training steps — device pairing, serial binding, camera binding, calibration check and teleoperation check — all in one place, greatly streamlining your setup for education labs, R&D PoCs and early‑stage robot validation projects.
Arm Type
SO-ARM101
Leader Arm
Follower Arm
Motor Configuration
1 × 7.4 V motor, 1:345 gear ratio — Joint 2
12x (12V) 1:345 gear ratio motors for all joints
2 × 7.4 V motors, 1:191 gear ratio — Joints 1 & 3
3 × 7.4 V motors, 1:147 gear ratio — Joints 4 & 5 & Gripper
Power Supply
DC 5V3A
DC 12V2A
DoF
5+1
Payload
500g
Angle sensor
12-bit magnetic encoder
Operating Temperature Range
0℃~40℃
Communication Method
UART
Control Method
PC
What’s inside each kit?
Which Kit Is Right For You?
 SO-ARM101 Pro Servo Motor KitSO-ARM101 Pro Unassembled BundleSO-ARM101 Pro Kit
Price$189.00$295.00$299.00
AssemblyStructural parts to be 3D‑printed by userAssembly from cratchPre-assembled
USB CameraExcludedExcludedIncluded
Best ForUsers with existing 3D-printed frames or custom enclosuresHobbyists who enjoy the build process and want a complete kit. Select accessories as you like.Researchers, educators, and teams who want to skip the build and focus on AI
Time to First Experiment8+ hours2-3 hoursUnder 30 minutes
Disclaimer
Seeed Studio only provides the hardware required for LeRobot.
For SO-ARM10x hardware , please refer to: TheRoboStudio for synchronized updates.
For software and tutorials, please follow: Huggingface/Lerobot.
Please promptly report the issue to the LeRobot platform or the LeRobot Discord channel.
Hardware Overview
Application
Leader‑Follower Teleoperation
Collect robot demonstration data easily via leader‑follower teleoperation, ready for imitation‑learning model training.
Imitation Learning & Reinforcement Learning
Teach your robot household‑style skills like folding clothes with human demos. Gather data via leader‑follower teleoperation, train imitation‑learning policies on LeRobot, and watch your robot reproduce tricky real‑world manipulation tasks.
SO-101 works seamlessly with LeRobot for data collection, simulation, training, and deployment. Train and deploy custom grasp-and-place policies quickly on NVIDIA Jetson edge devices.
Explore the tutorial: LeRobot on NVIDIA Jetson AI Lab
Community Inspiration
Follow Nikodem Bartnik’s hands‑on SO‑101 workflow: hardware assembly, servo control, custom policy training and real‑time block‑picking inference. Walk through key steps, fix typical issues and explore the open‑source arm’s potential.
Our monthly project call is now open! Share your project demos for a chance to win prizes and discount coupons.
Quick Start Developer Resources
Jumpstart your project with official tutorials, open-source repositories, and community support:
  • Start building your first Physical AI Project in 30 mins with SenseCraft
  • Step-by-Step Guide: SO-ARM 101 Quick Start
  • Open-Source Code: Access PyTorch models, simulation tools, and datasets on the Hugging Face LeRobot GitHub Repository
  • Community & Support: Join discussions, share models, and get real-time help on the Seeed Discord Channel & FaceBook. Join our Facebook Group to claim exclusive coupons worth up to $100 USD.
This parts list only shows items included in the default selected purchase options:
x1
x2
x3
x6
x2
Stud
x8
Screw
x8
5V Power Supply Cable (Multiple head)
x1
12V Power Supply Cable (Multiple head)
x1
USB-C Cable
x2
DC Power Pigtail Cable
x2
Fixing clip
x4
SO-ARM101 Pro 3D Printed Parts
Leader Parts12 pcs
Follower Parts11 pcs
Clamps Parts12 pcs
Camera
32*32mm USB Camerax1
The SO-ARM101 is fully open-source. All 3D-printable structural files, the bill of materials, circuit schematics, and firmware are publicly available. You are free to modify, extend, and redistribute your changes.
LeRobot is the primary software stack and the recommended starting point. ROS integration is community-driven — several community members have built ROS 2 bridges for the STS3215 servos, but these are not officially maintained.
The SO-ARM101 features improved internal cable routing (preventing the common joint-3 disconnection issue), redesigned bearing mounts that reduce backlash, and optimized leader arm motors with three different gear ratios for a more natural manual guidance feel. The SO-ARM100 is now considered deprecated in the official LeRobot documentation.
Yes. The LeRobot library runs on NVIDIA Jetson boards with JetPack + Ubuntu. Running inference on a Jetson allows autonomous, untethered operation — ideal for demos, deployments, and mobile setups.
Yes. The leader-follower teleoperation workflow requires two arms: one configured as the leader (moved by hand) and one as the follower (mirrors and records motion). A single kit is sufficient for scripted motion programming and servo debugging only.
The pre-assembled version comes with a camera, while you need to add the camera as a separate selection for the DIY kit. The camera is not included and must be sourced separately. Any 720p or higher USB webcam is compatible with the official LeRobot tutorials. For dual-camera configurations, please use two cameras from different manufacturers, as identical models may trigger USB path reassignment issues and crash the data recorder.
Any laptop or desktop running Ubuntu, macOS, or Windows with Python 3.10+. An NVIDIA GPU significantly accelerates model training — a 52M-parameter ACT model trains in approximately 4 hours on a 12GB RTX 3080. CPU-only training is possible for smaller datasets but considerably slower.
[7% OFF] SO-ARM101 Pro Unassembled Bundle – LeRobot Compatible 6DOF Robotic Arm
SKU E26070901
Build it your way. The SO-101 DIY Kit is designed for LeRobot and Hugging Face projects, allowing you to select the motors, 3D-printed parts, and USB camera you need to build your own imitation learning robotic arm. Fully open-source, affordable, and built for learning, prototyping, and robotics development.
7% discount is offered when purchasing this bundle.
JPY¥49035.00
[新製品] SO-ARM101 低コストAIアームサーボモーターキット プロ版(LeRobot用)(3Dプリント部品なし)x1¥39553.00
[新製品] SO-ARM101 低コストAIアーム 3Dプリント製骨格x1¥4733.00
RGB USB Camera-100°-720Px1¥4749.00
