製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Exciting News: Only 50 kits! Enjoy a 50% discount on our 4G or LoRaWAN® Solution Kits - first come, first served!
●4G Solution Kit
●LoRaWAN® Solution Kit
The CO2, temperature, and humidity sensor supports Modbus-RTU/ASCII RS485 and SDI-12 communication protocols, built-in calibration functionality, and is compact in size, making it widely applicable in greenhouses, cities, poultry farms, transportation stations, and other application scenarios where CO2 level is needed.
  • 3-in-1 sensor: Measure Carbon dioxide(CO2), air temperature, relative humidity
  • Wide Range & High Accuracy of CO2: 0ppm ~ 10,000 ppm, ± (40ppm+3%*MV)
  • High performance: high accuracy, fast response, and superior stability
  • Wide-range Power Supply and 2 protocols: 5V ~ 24V power supply, support RS485(Modbus -RTU / Modbus -ASCII) and SDI-12 protocols
  • User-friendly: factory-calibrated, supports custom calibration by pressing keys or using commands, easy to install and integrate
This is a digital CO2 concentration sensor based on NDIR (nondispersive infrared), which can continuously collect and calculate the CO2 concentration in the air per unit volume and output in the form of a universal interface. It's designed to adopt PTFE film combined with a protective enclosure, improving its breathable performance. It is more accurate, stable, reliable, low-power consumption, and user-friendly. It compacts in size and can be easily integrated into various application scenarios.
This digital NDIR CO2 concentration sensor supports RS485(Modbus -RTU / Modbus -ASCII) and SDI-12 communication protocols and is compatible with the wide power supply voltage of 5-24V. It has a built-in calibration functionality and can be widely applied in both indoor and outdoor environments. This product also adopts both single-air-chamber and double-channel. This CO2 Sensor (Version CO2-Connector) comes with a waterproof aviation connector, helping you save time and effort in wiring the sensor to a data logger with screws.
Connect with 4G Sensor Hub or LoRaWAN Data Logger for Remote Transmission
We offer the SenseCAP S2100 - LoRaWAN® Data Logger - Seeed Studio and SenseCAP Sensor Hub 4G Data Logger suitable for SenseCAP ONE series weather sensors, you can transmit the sensor data to public LoRaWAN® network servers(Helium, TTN, etc.,) or private servers.
Applications
  • Smart Agriculture
  • Smart Cities
  • Industry and Building ventilation systems
  • Airport, train station, shopping mall, home, office, classroom, and others
  • public places for air quality measurement and indication
  • Lab, warehouse, and other places to monitor the CO2 level
Specifications
Basic Parameters
Product Model
S-CO2-03A / S-CO2-03B
Supply Voltage
5 ~ 24 V
Supporting Protocols
Modbus -RTU RS485/ Modbus -ASCII RS485/ SDI-12 (v1.4)
IP Rating
IP65 (shading measures are required for outdoor installation, and the equipment cannot be exposed to direct sunlight and rainwater for a long time)
Operating Temperature
0°C ~ +50°C (Due to CO2 sensor limitations)
Working Humidity
0 ~ 95 %RH (no condensation)
Cable Length
2 meters
Measurement Parameters
Range
Accuracy
Resolution
Carbon Dioxide
0 ~ 10000ppm
±(50ppm+3%*MV)
1ppm
Air Temperature
-40~85°C
±0.2℃
0.01°C
Air Humidity
0~100%RH
±1.8%RH
0.01%RH
Wiring Diagram and Calibration Button
Sensor onboard a switch and a button:
  • Switch: select protocols(RS485/SDI-12), default is RS485.
  • Button: press the button for 5 seconds can calibrate the sensor value to 400ppm.
Sensor
x1
Mounting Bracket
x1
Self-drilling Screw - 2cm
x4
Self-drilling Screw - 6mm
x3
認証
HSCODE9031809090
USHSCODE9031808085
UPC
EUHSCODE9013101000
COOCHINA
SenseCAP CO2, Temperature and Humidity Sensor with RS485&SDI-12 , with Waterproof Aviation Connector
SKU 101991029
JPY¥12504.00
