おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Lichee Nano is an SD Card Sized Linux Development Board Powered by Allwinner F1C100s ARM9 Processor
Features/Specifications
  • CPU
-Allwinner F1C100s, ARM 926EJS processor,up to 900MHz
  • Memory & storage
-32MB DDR integrated into SoC, 16MB SPI Flash
-Onboard TF Slot, can be boot from TF Card,
  • Display
-40-pin RGB LCD FPC connector supporting 272×480, 480×800, 1024×600
and other resolutions resistive displays(and capacitive displays trough the adapter board).
-Support 720P video output, support video stream decoding such as H.264 / MPEG
  • Communication Interface
-SDIO for WiFi module
-SPI x2, TWI x3, UART x3
-OTG USB x1, TV out
  • Other interface
-PWM x2, LRADC x1
-Headphone output x2, Mic x1
  • Electrical characteristics
-Input 5V via micro USB port, 3.3 to 5V via pin
-Output – 3.3V, selectable input RTC voltage
-Power Consumption – 54mA (idle) with Linux, 250mA with display
-Storage Temperature: -40~125°C; operating: -20 to 70°C
Software and development environment
  • Support 3.10 BSP linux,
  • Support 4.19 mainline linux,
  • Support xboot bare metal development environment
  • Support RT-Thread
Target application scenario:
  • IoT applications using more complex communication interfaces and protocols
  • The application of human-computer interaction interface that needs more beautiful and complex logic
  • Application scenarios that require more operations (as opposed to common MCUs)
  • Need to use open source software under Linux for rapid development scenarios
  • High-end geek players balance in size, performance and ease of use.
  • Entry level player, software engineer, hardware diy using familiar language
Note
If you are looking for open source SBC for commercial and industrial needs. Seeed provides customization service based on BeagleBone series boards. Seeed Studio BeagleBone® Green(BBG) and Seeed Studio BeagleBone® Green Wireless (BBGW) provide more stable industrial deployment scenarios.
認証
HSCODE8517180050
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
認証
Size and weight
Core board size25.4x33.0mm
Core board weight4.2±0.2g
Precautions
start upNano needs card boot  (or  solder  SPI  flash), only plug in USB without any phenomenon
System debug serial portUART0, specific position reference pin diagram
USB interfaceOTG usb, power and communication
Operating temperature-20~70℃
Lichee Nanox1
WiFi Modulex1
OTGx1
LicheePi Nano ARM926EJS SoC Development Board - 16M Flash & Wi-Fi
SKU 102110201
USD$11.70
廃番
product.detail.alsoAdd.title
