おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Features:
  • Mono Cel Solar Cells
  • Working temperate from -20°C to 70°C
  • Peak Power: 12W
  • Durable: suitable for long-term outdoor applications
  • Robustness: the sturdy frame protects the solar panel from deformation
  • Easy installation: comes with a bracket
  • Waterproof aviation connector: save your time and can directly connect the cable to a data logger
Measuring weather and other data for outdoor application scenarios often requires sensors and data loggers in places far from any power grid. To supply power to remote sensor infrastructure, a sensor system can generate its own power. In most cases, the cheapest and most convenient method is solar panels combined with a battery. When the sun is bright enough solar panels provide enough electricity to power the sensor system and charge the battery for the night or during times when the sunlight is not sufficient.
The 12W Solar Panel can be used as a convenient, cheap, and clean solution for supplying power of your applications such as environmental monitoring in agriculture, forestry, garden, or a security camera in your home or garden, etc.
As most of Seeed IIoT products are aiming for environmental sensing scenarios, this 12 Solar Panel will come in handy for your applications with Seeed IIoT products: SenseCAP Sensor Hub and its Sensors. The Solar panel is robust enough to withstand the harsh conditions required in agriculture and environmental monitoring. The 6-pin waterproof aviation connector can be directly connected to the Sensor Hub. It charges the integrated battery of the Sensor Hub to supply electricity when the solar panels do not supply enough power.
Applications:
Solar panels can be used where there is no power grid and enough sunlight to generate the necessary power for the sensor infrastructure.
Environmental monitoring in remote areas like monitoring weather conditions in national parks or monitoring soil conditions on farmland are just some possible applications.
  • Environmental Monitoring
  • Agriculture
  • Research
  • Meteorological Monitoring
  • Smart Home/ Garden/ Security Camera
  • Other applications that needs 12W power supply
Solar panel parameters
Module type
Monocrystalline silicon
Peak power
12Wp
Open circuit voltage
14V
Short circuit current
1A
Package size
350mm*250mm*25mm
Package weight
3kg
Technical Parameters of Photovoltaic Modules
Solar cell type
Index
Unit
Data
Peak power
Wp
12
Open circuit voltage(Voc)
V
14
Short circuit current (Isc)
A
1
Working voltage (Vmppt)
V
12
Working current (Imppt)
A
1
maximum voltage the system
can withstand
Vdc
1000
Module size
mm
350*250*25
Peak power temperature
coefficient
-0.45
temperature coefficient
-0.35
Short-circuit current
+0.05
Operating temperature range
-20~70
Maximum wind/snow load
Pa
2400/5400
Equipment
 list
Item
Name
Quantity
Remarks
1
Photovoltaic module
12W solar panel with cable and waterproof connector
1
Note: the wiring diagram for details
2
Stand
Equipment to install the solar panel
1
3
Packing box
Customized according to the size
1
認証
HSCODE8541402000
USHSCODE8541410000
UPC
EUHSCODE8531202090
COOCHINA
High-efficiency Waterproof PV-12W Solar Panel, w/ Brackets for Easy Installation
SKU 114992711
A high-efficiency robust 12W solar panel to supply power to various application scenarios such as smart agriculture and smart city.
5-Pin Sensor Connector
JPY¥10288.00
product.detail.alsoAdd.title
