製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Connector for electrical devices and machinery
  • Copper plated welding connector
  • Temperature range: -40°C~85°C
  • Made with Thermoplastic
  • IP68 rated
The IP68 Waterproof 5-pin Aviation Connector SP1310/P5 can be connected to electrical devices such as sensors and equip the devices with waterproof functionality, and at the same time make it easier to use with other devices by a simple plug. This is a fin-pin plug, you can solder the pins to the respective cables/sockets on your electronic devices.
Seeed SenseCAP Sensor Hub 4G Data Logger has 4 waterproof aviation sockets. If you’d like to use your existing sensors with the Sensor Hub, you can grab some of these IP68 Waterproof 5-pin Aviation Connector SP1310/P5, solder them to your sensors, and you can connect them to Sensor with a simply plug. After some provisioning, you will be able to see the data conveniently.
Applications
  • Machine Tools
  • Electromechanics
  • Communications
  • Instrumentation
  • Lighting systems
  • Vehicle-mounted equipment
認証
HSCODE8536690000
USHSCODE8536698000
UPC
EUHSCODE8531202090
COOCHINA
IP68 Waterproof 5-pin Aviation Connector/Cable Plug SP1310/P
SKU 320991108
The IP68 Waterproof 5-pin Aviation Connector SP1310/P5 can be connected to electrical devices such as sensors and equip the devices with waterproof functionality.
JPY¥412.00
