製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • 5 parameters measurement: Measures air temperature, relative humidity, barometric pressure, wind speed, and wind direction in 1 single sensor
  • Industrial-level design: -40°C to +85°C operating temperature, IP66 rated: waterproof, and dustproof, suitable for outdoor scenarios
  • Output interface: RS485 (MODBUS-RTU) / SDI-12
  • Thermostatically-controlled heating system: Independent heating power supply for use in extremely cold environments
  • Powerful Components Included: A 3m cable for the pole mount; radiation shields are equipped to ensure accurate ambient measurement; ultrasonic wind speed & direction sensors without moving parts
  • High-performance Guarantee
  • Wind tunnel for wind calibration
  • High-Low Temperature Test - determine performance under adverse temperature conditions.
  • Structural Test - whether the collected values of multiple devices are consistent
  • x-y-z vibration test
  • Waterproof and air tightness test
  • R&D and Production Test - to test the pass rate of multiple devices under factory conditions
仕様
General Parameters
Parameters Measured
air temperature, relative humidity, barometric pressure, wind speed and wind direction
Protocol
Power Supply
12V~24V
24V(Heating power supply)
Cable Length
3m
Operating Temperature & Humidity
-40 °C ~ + 85 °C, 0 ~ 100%RH
IP Rating
IP66
Device Weight
2kg
Air Temperature
Range
- 40 °C ~ + 85 °C
Accuracy
± 0.1℃
Resolution
0.01 ℃
Air Humidity
Range
0 ~ 100% RH
Accuracy
± 1.5% RH
Resolution
0.01% RH
Barometric Pressure
Range
300 ~ 1250 hPa
Accuracy
± 50 Pa
Resolution
10 Pa
Wind Speed (Ultrasonic)
Range
0~60 m/s standard range
0~75m/s extended range
Up to 80m/s withstand range
Accuracy
±0.3m/s(≤10m/s);
±3% (10m/s ~ 50m/s)
±5% (>50m/s)
Resolution
0.1 m/s
Wind Direction (Ultrasonic)
Range
0 ~ 360 °
Accuracy
± 3.0°
Resolution
0.1°
ハードウェア概要
用途
  • Backyard and Garden: Measure air temperature and humidity, Rainfall Intensity, UV index, etc. in the backyard and garden to protect your family.
  • Smart Agriculture: Enable farmers to obtain climate data and information in time, take scientific management measures into production, and improve agricultural production capacity and level.
  • Meteorology: Support applications in the professional meteorological field, for example, timely reflect the changes of various abnormal meteorological conditions in the field of traffic and transportation to provide real-time scientific basis data for traffic management departments.
  • Urban Weather: Provide real-time data for urban squares, parks, scenic spots, golf courses, and other urban areas.
  • Transportation and Traffic: Supplies real-time local weather measurements for roads, transport facilities, and traffic management systems operating under changing outdoor conditions.
Today, data on localized weather, known as microclimates, is the new frontier for more precise and accurate weather forecasting. As a result, the collection of weather data is becoming increasingly smaller and gridded. In light of this, weather sensors, which are the most convenient means of collecting weather data, are seeing a rise in demand.
This SenseCAP ONE S500 5-in-1 Compact Weather Sensor can help you collect and monitor environmental and weather data, which are crucial in different application scenarios such as smart city projects and etc. It's IP66 certified, and it features strong robustness to withstand even the toughest outdoor environment. The Sensors to measure wind speed and wind direction use ultrasound instead of a traditional mechanical 3-cup or vane anemometer. The advantage of using ultrasonic sensors is that reducing the movable parts can make the sensor less likely to break and thereby is easier to be maintained without any sacrifices in precision or manpower.
SenseCAP ONE is a series of all-in-one compact weather sensors, that integrate multiple sensors into this compact device, monitoring up to 10 weather parameters: air temperature, air humidity, atmospheric pressure, light intensity, wind speed, wind direction, precipitation, PM 2.5, PM 10, and CO2.
The SenseCAP ONE series uses the RS485 (MODBUS-RTU) / SDI-12 communication protocol. Hence, the SenseCAP ONE compact weather sensor can be used with any data logger that supports RS485 (MODBUS-RTU) / SDI-12.
We offer the https://www.seeedstudio.com/SenseCAP-S2100-LoRaWAN-Data-Logger-p-5361.html and https://www.seeedstudio.com/SenseCAP-Sensor-Hub-4G-Data-Logger-with-builtin-battery-p-4852.html suitable for SenseCAP ONE series weather sensors, you can transmit the sensor data to public LoRaWAN® network servers(Helium, TTN, etc.,) or private servers.
認証
HSCODE9031900090
USHSCODE9031808085
UPC
EUHSCODE8517180000
COOCHINA
部品リスト
SenseCAP ONE All-in-one Compact Weather Sensor
x1
M12 8-pin communication cable (default length 3-meter hook-up wire and there is a waterproof aviation connector type to choose from when working with SenseCAP SensorHub datalogger. If the aviation connector is not needed, cut it off by yourself)
x1
USB Type-C cable, for configuring devices
x1
Screw
x6
Flat washer (to open the configuration port)
x1
SenseCAP S500 V2 5-in-1 Compact Weather Station
SKU 101991021
S500 5-in-1 Compact Weather Sensor measures air temperature, relative humidity, barometric pressure, wind speed, and wind direction (ultrasonic). It is ideal for application in a rough environment like outdoors, agriculture, or smart cities.
Use it with SenseCAP S2100 - LoRaWAN® Data Logger - Seeed Studio or Sensor Hub industrial-grade 4G Data Logger with MODBUS-RTU RS485 protocol - Seeed Studio
JPY¥94806.00
