おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • 8 parameters measurement : Measures air temperature, relative humidity, barometric pressure, wind speed, wind direction, PM2.5, PM10 and noise in 1 single sensor
  • Industrial-level design : -40°C to +85°C operating temperature, IP66 rated: waterproof, and dustproof, suitable for outdoor scenarios
  • Output interface : RS485 (MODBUS-RTU) / SDI-12
  • Thermostatically-controlled heating system : Independent heating power supply for use in extremely cold environments
  • Powerful Components Included : A 3m cable for the pole mount; radiation shields are equipped to ensure accurate ambient measurement; ultrasonic wind speed & direction sensors without moving parts
  • High-performance Guarantee
  • We are well aware that the sensors may work under harsh outdoor conditions. To ensure that the performance and durability of the sensors are consistent with their specifications throughout the complete lifecycle, SenseCAP ONE Serials Sensor went through 6 reliability tests before releasing and met the requirements to perform perfectly in extreme conditions.
    • Wind tunnel for wind calibration
    • High-Low Temperature Test - determine performance under adverse temperature conditions.
    • Structural Test - whether the collected values of multiple devices are consistent
    • x-y-z vibration test
    • Waterproof and air tightness test
    • R&D and Production Test - to test the pass rate of multiple devices under factory conditions
    仕様
    General Parameters
    Parameters Measured
    Protocol
    Power Supply
    12V~24V
    24V(Heating power supply)
    Cable Length
    3m
    Operating Temperature & Humidity
    -40 °C ~ + 85 °C, 0 ~ 100%RH
    IP Rating
    IP66
    Device Weight
    2kg
    Air Temperature
    Range
    - 40 °C ~ + 85 °C
    Accuracy
    ± 0.1℃
    Resolution
    0.01 ℃
    Air Humidity
    Range
    0 ~ 100% RH
    Accuracy
    ± 1.5% RH
    Resolution
    0.01% RH
    Barometric Pressure
    Range
    300 ~ 1250 hPa
    Accuracy
    ± 50 Pa
    Resolution
    10 Pa
    Wind Speed (Ultrasonic)
    Range
    0~60 m/s standard range
    0~75m/s extended range
    Up to 80m/s withstand range
    Accuracy
    ±0.3m/s(≤10m/s);
    ±3% (10m/s ~ 50m/s)
    ±5% (>50m/s)
    Resolution
    0.1 m/s
    Wind Direction (Ultrasonic)
    Range
    0 ~ 360 °
    Accuracy
    ± 3.0°
    Resolution
    0.1°
    PM2.5
    Range
    0~1000µg/m³
    Accuracy
    ±10% (100~1000µg/m³)
    ±10µg/m³ (0~100µg/m³)
    Resolution
    1µg/m³
    PM10
    Range
    0~1000µg/m³
    Accuracy
    ±15% (100~1000µg/m³)
    ±15µg/m³ (0~100µg/m³)
    Resolution
    1µg/m³
    Noise
    Range
    35~100dB
    Accuracy
    ±1.5dB
    Resolution
    0.1dB
    ハードウェア概要
    用途
    Smart Agriculture: Serves as a compact agriculture and farm weather station, providing localized weather, rainfall, wind, and solar radiation data to support irrigation scheduling, crop management, and daily farm operations.
    Smart City: Provides localized weather data for environmental monitoring, public infrastructure management, and weather-aware urban operations.
    Power Transmission: Monitors wind, rainfall, temperature, and other local weather conditions around transmission infrastructure to support inspection and operational planning.
    Renewable Energy: Measures solar radiation and surrounding weather conditions to support the monitoring and operation of solar and other renewable energy sites.
    Transportation and Traffic: Supplies real-time local weather measurements for roads, transport facilities, and traffic management systems operating under changing outdoor conditions.
    Today, data on localized weather, known as microclimates, is the new frontier for more precise and accurate weather forecasting. As a result, the collection of weather data is becoming increasingly smaller and gridded. In light of this, weather sensors, which are the most convenient means of collecting weather data, are seeing a rise in demand.
    This SenseCAP ONE S800 8-in-1 Compact Weather Sensor can help you collect and monitor environmental and weather data, which are crucial in different application scenarios such as smart city projects and etc. It's IP66 certified, and it features strong robustness to withstand even the toughest outdoor environment. The Sensors to measure wind speed and wind direction use ultrasound instead of a traditional mechanical 3-cup or vane anemometer. The advantage of using ultrasonic sensors is that reducing the movable parts can make the sensor less likely to break and thereby is easier to be maintained without any sacrifices in precision or manpower.
    SenseCAP ONE is a series of all-in-one compact weather sensors, that integrate multiple sensors into this compact device, monitoring up to 10 weather parameters: air temperature, air humidity, atmospheric pressure, light intensity, wind speed, wind direction, precipitation, PM 2.5, PM 10, and CO2.
    The SenseCAP ONE series uses the RS485 (MODBUS-RTU) / SDI-12 communication protocol. Hence, the SenseCAP ONE compact weather sensor can be used with any data logger that supports RS485 (MODBUS-RTU) / SDI-12.
    We offer the SenseCAP S2100 - LoRaWAN® Data Logger - Seeed Studio and Sensor Hub industrial-grade 4G Data Logger with MODBUS-RTU RS485 protocol - Seeed Studio suitable for SenseCAP ONE series weather sensors, you can transmit the sensor data to public LoRaWAN® network servers(Helium, TTN, etc.,) or private servers.
    認証
    HSCODE9031900090
    USHSCODE9031808085
    UPC
    EUHSCODE8517180000
    COOCHINA
    部品リスト
    SenseCAP ONE All-in-one Compact Weather Sensor
    x1
    M12 8-pin communication cable (default length 3-meter hook-up wire and there is a waterproof aviation connector type to choose from when working with SenseCAP SensorHub datalogger. If the aviation connector is not needed, cut it off by yourself)
    x1
    USB Type-C cable, for configuring devices
    x1
    Screw
    x6
    Flat washer (to open the configuration port)
    x1
    SenseCAP S800 8-in-1 Compact Weather Sensor
    SKU 101991023
    SenseCAP S800 8-in-1 Compact Weather Sensor measures air temperature, relative humidity, barometric pressure, wind speed, wind direction (ultrasonic), PM2.5, PM10, and noise. It is ideal for application in a rough environment like the outdoors, agriculture, or smart cities.
    Use it with SenseCAP LoRaWAN Data Logger or SenseCAP 4G Data Logger.
    USD$799.00
    product.detail.alsoAdd.title
