Comprehensive 6-parameter Measurement
The S600-A is equipped with multiple sensors measuring crucial parameters for gathering a wealth of environmental data, including air temperature, relative humidity, barometric pressure, wind speed, wind direction and light intensity.
Industrial-level Design
Wide operating temperature range from -40°C to +85°C and High Protection Rating of IP66
Versatile Output Interface
The S600-A offers 2 common and reliable output interfaces, namely RS485 (supports MODBUS-RTU protocol) and SDI-12.
Thermostatically-controlled Heating System
This heating system is thermostatically controlled, ensuring that the device can maintain its normal working state and accurate measurement capabilities at extremely cold temperatures.
Powerful Components
Reliable and High Standard Test Performance
Specification | Parameter | |
Measurement parameters | Air temperature(℃) Relative humidity(%) Barometric pressure(Pa) Wind speed(m/s) Wind direction(°) Light intensity(Lux) | |
Interface | M12 connector | |
Communication Protocol | RS485(Modbus-RTU)/SDI-12/ASCII | |
Power Supply | 12V~24V 24V(Heating power supply) | |
Power Consumption | 0.4W(heating 21W) | |
Cable Length | 3m | |
Ambient Condition | ||
IP Rating | IP66 | |
Operation Temperature | -40 °C ~ + 85 °C | |
Humidity | 0 ~ 100%RH(no condensation) | |
Mechanical | ||
Dimension | 140x140x320mm | |
Weight | 1470g | |
Certification | ||
RoHS | ||
Measurement parameter | Principle | Range | Resolution | Accuracy |
Air temperature(℃) | - | - 40 °C ~ + 85 °C | 0.01 ℃ | ± 0.1℃ |
Relative humidity(%) | - | 0 ~ 100% RH | 0.01% RH | ± 1.5% RH |
Barometric pressure(Pa) | - | 300 ~ 1250 hPa | 10 Pa | ± 50 Pa |
Wind speed(m/s) | Ultrasonic | 0~60 m/s standard range 0~75m/s extended range Up to 80m/s withstand range | 0.1 m/s | ±0.3m/s(≤10m/s); ±3% (10m/s ~ 50m/s) ±5% (>50m/s)
Wind direction(°) | Ultrasonic | 0 ~ 360 ° | 0.1° | ± 3.0° |
Light intensity | - | 0~200000 Lux | 5Lux | ±5% |
The equipment uses M12 connectors with an 8-core specification. Cables in 8 different colors are used to supply power to the equipment and for data communication.
The bottom wire outlet is 3m. There is a six-core wire cable, including wires in colors of white, brown, green, yellow, gray, pink, blue and red.
The SenseCAP ONE series supports connection to various data acquisition devices, Programmable Logic Controllers (PLCs) or Host Computers via RS485, ASCII and SDI-12 protocols.
SenseCAP ONE Series Comparison
Smart Agriculture: Serves as a compact agriculture and farm weather station, providing localized weather, rainfall, wind, and solar radiation data to support irrigation scheduling, crop management, and daily farm operations.
Smart City: Provides localized weather data for environmental monitoring, public infrastructure management, and weather-aware urban operations.
Power Transmission: Monitors wind, rainfall, temperature, and other local weather conditions around transmission infrastructure to support inspection and operational planning.
Renewable Energy: Measures solar radiation and surrounding weather conditions to support the monitoring and operation of solar and other renewable energy sites.
Transportation and Traffic: Supplies real-time local weather measurements for roads, transport facilities, and traffic management systems operating under changing outdoor conditions.
| HSCODE | 9031809090 |
| USHSCODE | 9031808085 |
| UPC | |
| EUHSCODE | 9013101000 |
| COO | CHINA |
component name | quantity |
SenseCAP S600-A 6-in-1 Compact Weather Station | x 1 |
M12 8-pin communication cable | x 1 |
USB Type-C cable | x 1 |
Screw | x 6 |
Flat washer | x 1 |
It can measures air temperature, relative humidity, barometric pressure, wind speed, wind direction (ultrasonic) and light intensity. It is ideal for application in a rough environment like the outdoors, agriculture, or smart cities.
Use it with SenseCAP LoRaWAN Data Logger or SenseCAP 4G Data Logger.
