製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Compact & Integrated Design: A compact all-in-one design integrates multiple environmental sensors, including temperature, humidity, atmospheric pressure, light and CO₂, along with built-in 4G communication, reducing installation complexity and saving space in the field.
  • Multi-Sensor Expansion with Strong Compatibility: The device is equipped with an RS485 interface and supports expansion via a splitter to connect up to 10 external sensors. It is fully compatible with Modbus-RTU RS485 standard protocol, enabling seamless integration with industrial sensors. It provides both 5V and 12V power output for connected sensors.
  • Solar-Powered & Flexible Power Supply Options: The device is powered by an integrated solar panel and a built-in 5200mAh rechargeable Li-ion battery, making it ideal for remote deployments. For scenarios that require stable power, it also supports external DC input(Type-C interface), providing greater flexibility across different use case.
  • Reliable Data Caching: Stores up to 500,000 records locally during 4G signal loss. Data auto-uploads once connectivity restores, and historical logs can be exported directly for easy analysis.
  • Low Power Design for Long Battery Life: The device adopts an ultra-low power design and can operate for over two weeks when solar power is insufficient or during power outages.
  • Greenhouse Operation: Designed for greenhouse and indoor agricultural environments, it operates reliably from 0°C to 40°C.
  • Weatherproof Design: Featuring an IPX5 rating and UV-resistant materials, the device is protected against rain and aging, making it perfect for greenhouses and outdoor use.
  • Easy Maintenance with OTA Updates: Support for over-the-air (OTA) firmware upgrades allows remote maintenance and feature updates, reducing the need for on-site servicing and keeping your device always up to date.
  • Easy Deployment: Designed for quick setup, the device is ready to use out of the box. The device supports flexible mounting options, including pole and hanging installation, making it suitable for various environments.
Note:
The device is suitable for greenhouse and indoor agricultural applications. The included power adapter is for indoor use only and must be installed in a waterproof enclosure or electrical cabinet when used outdoors. The device should also be operated within the specified temperature range of 0°C to 40°C.
仕様
General Parameters
Power SupplyType-C interface, 5V/2A input
Expansion Inteface1x RS485 (Modbus-RTU)
Number of Connectable SensorsSupports up to 10 external sensors using Splitter
External Sensor Power Output12V / 0.35A, 5V / 0.35A
ProtocolMQTT protocol; supports user-configured servers via Sensor Hub Configuration Tool NG
4G Cat.1Global frequency bands / APN configurable; Micro SIM card / 3FF
Data CachingLocal storage for up to 500,000 cached records / Supports local export
AntennaBuilt-in antenna
Switch / LED Indicators1x Power Switch, 2x LED Indicators
IP RatingIPX5, PCBA Waterproof Treatment
UV Resistance RatingF1
Enclosure MaterialPC/ASA
Operating Temperature
0°C ~ 40°C
Note:
The operating temperature of the device is limited by the included power adapter, which supports an operating temperature range of 0°C to 40°C.
The power adapter is designed for indoor use only. Do not expose the power adapter directly to outdoor environments. The power adapter must be installed inside a waterproof enclosure or electrical cabinet to ensure proper protection.
Charging temperature0°C ~ 40°C
Operating Humidity0 ~ 100 %RH (non-condensing)
Battery5200mAh, 3.7V rechargeable Li-ion battery
Solar PanelMaximum power 1W
InstallationHanging or Pole-mount (Requires wire for hanging; brackets for pole-mount. Not included in package)
Dimensions202 * 202 * 175 mm
Net Weight0.8 kg
Sensor Specifications
ParameterRangeAccuracyResolution
Air Temperature-40°C ~ +85°C±0.2°C0.01°C
Air Humidity0 ~ 100%RH (non-condensing)±2%RH0.01%RH
Dew Point (calculated by T/H algorithm)-100°C ~ 80°C±2°C0.01°C
Barometric Pressure300 ~ 1200 hPa1 hPa10 Pa
Light Intensity0 ~ 200,000 Lux±5%5 Lux
CO₂0 ~ 10,000 ppm±50ppm ±3%*reading (0~5000ppm); ±5% (5000~10000ppm)1 ppm
ModelSpecification
4G-YUN-03-GlobalAir Temp & Humidity, Atmospheric Pressure, Light Intensity, CO₂
Note:
For projects requiring additional environmental parameters, customized configurations with extended sensor options are also available. For customization inquiries, please contact [email protected]
ハードウェア概要
用途
  • Smart Agriculture: Optimizes crop growth by providing real-time monitoring of microclimates in greenhouses or other indoor agricultural sites, ensuring the balance of temperature, humidity, and light intensity.
  • Livestock Farming: Monitors air quality and CO₂ levels in barns, helping farmers maintain a healthy environment for their livestock.
  • Storage & Logistics: Protects sensitive goods and prevents spoilage in warehouses or cold chains by ensuring precise, continuous climate control and stable data logging.
  • Research & Education: Serves as a reliable tool for schools and laboratories, allowing students and researchers to collect accurate environmental data for scientific studies and climate analysis.
認証
HSCODE9025800090
USHSCODE9025801000
UPC
EUHSCODE9013101000
COOCHINA
部品リスト
SenseCAP Combo 5-in-1 Sensor with 4G(4G-YUN-03-Global)x1
Power Adapterx1
USB Cablex1
SKU 100035616
SenseCAP Combo 5-in-1 Sensor with 4G is designed for environmental monitoring. It measures temperature, humidity, atmospheric pressure, light, and CO₂ in one compact device. It supports up to 10 Modbus RTU RS-485 sensors and uploads data via 4G MQTT for remote monitoring. Powered by a solar panel with a backup battery, it ensures up to two weeks of operation during outages. The waterproof and UV-resistant housing ensures reliable performance in greenhouse environments, ideal for agriculture and long-term monitoring.
JPY¥40993.00
