S2120 is not maintenance-free. Its service life may be reduced in harsh environments.
SenseCAP LoRaWAN S2120 Weather Station collects and uploads air temperature, humidity, wind speed/direction, Rainfall Intensity, light intensity, UV index, and barometric pressure data supported by worldwide LoRaWAN networks. The S2120 weather station is suitable for applications in gardens, agriculture, meteorology, urban environmental monitoring, and other scenarios. It also enables low maintenance cost for its ultra-low power consumption, reliable performance, built-in Bluetooth for OTA configuration and remote device management.
Built-in Bluetooth avoids time-consuming configuration works to bring no code experience to individuals with less or no technical background to quickly get started with weather detection.
LoRaWAN network coverage is required when using sensors, there are two LoRaWAN network options.
Option 1: Sensors work in areas covered by Helium Network (Check on Helium Explorer).
Option 2: Sensors work in a standard LoRaWAN network, like The Things Network, Loriot, Chirpstack, etc (Check out the SenseCAP Gateway series).
We highly recommend that you use our SenseCAP M2 Multi-Platform LoRaWAN Gateway, which is a standard LoRaWAN® gateway that supports connection to different network servers. With its affordable price of $99, its cost-effectiveness becomes a standout advantage, especially when building your private LoRaWAN network.
Note
1. SenseCAP provides a GPS function customization service for the WM-LR1110 module. Please contact the mailbox:[email protected].
2. This is NOT the WXM weather station. If you would like to purchase the WXM weather station, please refer to: https://weatherxm.com/
Air Temperature | Rainfall Intensity | ||
Range | -40.0 ~ 80.0 ℃ | Range | 0 ~ 450 mm/h |
Accuracy | ±0.5℃ (0~80℃); ±0.6℃ (-40~0℃) | Accuracy | ± 7% |
Resolution | 0.1℃ | Resolution | 0.254 mm/h |
Air Humidity | General Parameters | ||
Range | 1~99 %RH | Product Model | S2120 |
Accuracy | ±3% (1~90%RH); ±4% (90~99%RH) | Microcontroller | WM-LR1110 |
Resolution | 1%RH | Support Protocol | LoRaWAN v1.0.3 Class A |
Barometric Pressure | Built-in Bluetooth | App Tool to change parameters | |
Range | 540 ~ 1100hPa | LoRaWAN Channel Plan | IN865/EU868/US915/AU915/ AS923/KR920/RU864 * |
Accuracy | ±5hPa(700~1100hPa); ±8hPa (540 ~ 699hPa) | GPS | Need to customize |
Resolution | 1hPa | LoRaWAN Max Transmitted Power | 21dBm |
Wind Speed | LoRa Sensitivity | -141dBm@SF12 BW=125KHz | |
Range | 0~50.0m/s | Communication Distance | 2 to10km (depending on gateway antenna and environments) |
Accuracy | ±0.5m/s(<5m/s ); ±10% (> 5m/s) | Protection grade | Suitable for outdoor scenes |
Resolution | 0.1 m/s | Operating Humidity | 0~99%RH |
Wind Direction | Device Weight | 1.5kg | |
Range | 0~360° | Certification | CE / FCC / RoHS |
Accuracy | ± 8° | Power Supply | |
Resolution | 1° | Solar Panel | 0.5W (When there is sunlight, solar panels will be used first, otherwise batteries will be used) |
Light Intensity | UV Index | ||
Range | 0 ~ 200000 lux | Range | 0 ~ 16.0 |
Accuracy | ± 5% | Accuracy | ±10% |
Resolution | 1 lux | Resolution | 0.1 |
Battery Type | Alkaline | Lithium |
Specification | AA size, 1.5V power supply (batteries not included) | |
Number of Battery | Option1, built-in battery box: 3 * AA battery Option2, external battery box: 6 *AA battery | |
External Battery Box | Support 6 * AA 1.5V batteries(batteries not included) Cable: 2m IP Rating: IPX6 | |
Operating Temperature Range | -10°C to 50°C (14°F to 122°F) | -40°C to 60°C (-40°F to 140°F) |
Rechargeable | No | No |
Temperature Performance | 40–50% capacity at -10°C (significantly increased internal resistance that may cause device reset during data transmission peaks); Have risk of electrolyte leakage and accelerated self-discharge above 45°C | Delivers 85–90% capacity at -20°C; Remains stable up to 60°C with minimal self-discharge acceleration |
Selection Guide | Urban and agricultural deployments with ambient temperatures consistently above -10°C | Cold climates where winter temperatures drop below -10°C |
Maintenance Guide | Replace every 6 months or upon remote low-battery alert | Replace every 12 months or upon remote low-battery alert |
Replacement Notice | When bringing stations from sub-zero environments into heated spaces for maintenance, allow the entire unit to reach room temperature and confirm zero condensation on internal surfaces before opening the battery compartment. Moisture on terminals causes corrosion and potential short circuits. | |
Note: As a commercial-grade weather station, the S2120 may experience accelerated aging of its internal sensors and batteries under certain extreme weather conditions (extremely high or low temperatures) and deployment environments (high salinity and humidity), which can cause the device to malfunction. Please select the appropriate battery type based on the actual temperature of the deployment environment.
Note: No Frequency limitation. Weather stations can be switched to other frequency plans at any time.
S2120 is manufactured to support the universal frequency plan from 863MHz ~928MHz in one SKU. That is to say, it can support the frequency plans below:
Frequency Plan | Common Name | Sub-band |
EU863-870 | EU868 | ___ |
US902-928 | US915 | Sub-band from 1 to 8 |
AU915-928 | AU915 | Sub-band from 1 to 8 |
AS923 | AS923 | AS923_1, AS923_2, AS923_3, AS923_4 |
IN865-867 | IN865 | ___ |
KR920-923 | KR920 | ___ |
RU864-867 | RU864 | ___ |
The frequency plan setting is none by default and it will not transmit RF signal until it has been set by App via Bluetooth at the first power-up. And it can be changed to other frequency plans at any time.
About SenseCAP
Among the first launch of the Seeed industrial IoT (IIoT) product series, SenseCAP is focusing on wireless environmental sensing applications: smart agriculture, precision farming, and smart city, to name a few. It consists of hardware products (sensors, data loggers & gateways, etc.), software services (SenseCAP portal, mobile App, open dashboard), and an API for device & data management.
SenseCAP LoRaWAN S2120 Weather Station provides you with hyperlocal weather at your fingertips. It supports multi-scenario applications like backyard, garden, agriculture, meteorology, urban environmental monitoring, and so on. It enables low maintenance cost for its ultra-low power consumption, reliable performance, and built-in Bluetooth for OTA configuration and remote device management.
