Product Details
Wiki & Learn
Reviews
Download PDF
Feature
What is the difference between S700, S700-B and S700-A?
Global solar radiation
Sunshine duration
Light Intensity
Rainfall Intensity
S700
Optical
S700-C
Radar
S700-B
Optical
S700-A
Radar
  • 7 parameters measurement: Measures air temperature, relative humidity, barometric pressure, light intensity, precipitation intensity, wind speed, and wind direction in 1 single sensor
  • Industrial-level design: -40°C to +85°C operating temperature, IP66 rated: waterproof, and dustproof, suitable for outdoor scenarios
  • Output interface: RS485 (MODBUS-RTU) / SDI-12
  • Thermostatically-controlled heating system: Independent heating power supply for use in extremely cold environments
  • Powerful Components Included: A 3m cable for the pole mount; radiation shields are equipped to ensure accurate ambient measurement; ultrasonic wind speed & direction sensors without moving parts
  • High-performance Guarantee
  • Wind tunnel for wind calibration
  • High-Low Temperature Test - determine performance under adverse temperature conditions.
  • Structural Test - whether the collected values of multiple devices are consistent
  • x-y-z vibration test
  • Waterproof and air tightness test
  • R&D and Production Test - to test the pass rate of multiple devices under factory conditions
General Parameters
Parameters Measured
air temperature, relative humidity, barometric pressure, wind speed, wind direction,rainfall intensity and light intensity
Protocol
Power Supply
12V~24V
24V(Heating power supply)
Cable Length
3m
Operating Temperature & Humidity
-40 °C ~ + 85 °C, 0 ~ 100%RH
IP Rating
IP66
Device Weight
2kg
Air Temperature
Range
- 40 °C ~ + 85 °C
Accuracy
± 0.1℃
Resolution
0.01 ℃
Air Humidity
Range
0 ~ 100% RH
Accuracy
± 1.5% RH
Resolution
0.01% RH
Barometric Pressure
Range
300 ~ 1250 hPa
Accuracy
± 50 Pa
Resolution
10 Pa
Wind Speed (Ultrasonic)
Range
0~60 m/s standard range
0~75m/s extended range
Up to 80m/s withstand range
Accuracy
±0.3m/s(≤10m/s);
±3% (10m/s ~ 50m/s)
±5% (>50m/s)
Resolution
0.1 m/s
Wind Direction (Ultrasonic)
Range
0 ~ 360 °
Accuracy
± 3.0°
Resolution
0.1°
Rainfall Intensity (Optical)
Range
0 ~ 200 mm/h
Accuracy
± 10%
Resolution
0.2 mm/h
Light Intensity
Range
0 ~ 200,000 Lux
Accuracy
± 5% of reading
Resolution
5 Lux
Hardware Overview
Application
Smart Agriculture, Smart City, Power Transmission, Renewable Energy, Transportation and Traffic
Today, data on localized weather, known as microclimates, is the new frontier for more precise and accurate weather forecasting. As a result, the collection of weather data is becoming increasingly smaller and gridded. In light of this, weather sensors, which are the most convenient means of collecting weather data, are seeing a rise in demand.
SenseCAP ONE is a series of all-in-one compact weather sensors, that integrate multiple sensors into this compact device, monitoring up to 10 weather parameters: air temperature, air humidity, atmospheric pressure, light intensity, wind speed, wind direction, precipitation, PM 2.5, PM 10, and CO2.
The SenseCAP ONE series uses the RS485 (MODBUS-RTU) / SDI-12 communication protocol. Hence, the SenseCAP ONE compact weather sensor can be used with any data logger that supports RS485 (MODBUS-RTU) / SDI-12.
We offer the SenseCAP S2100 - LoRaWAN® Data Logger - Seeed Studio and Sensor Hub industrial-grade 4G Data Logger with MODBUS-RTU RS485 protocol - Seeed Studio suitable for SenseCAP ONE series weather sensors, you can transmit the sensor data to public LoRaWAN® network servers(Helium, TTN, etc.,) or private servers.
Certification
HSCODE9031900090
USHSCODE9031808085
UPC
EUHSCODE8517180000
COOCHINA
SenseCAP ONE All-in-one Compact Weather Sensor
x1
M12 8-pin communication cable (default length 3-meter hook-up wire and there is a waterproof aviation connector type to choose from when working with SenseCAP SensorHub datalogger. If the aviation connector is not needed, cut it off by yourself)
x1
USB Type-C cable, for configuring devices
x1
Screw
x6
Flat washer (to open the configuration port)
x1
SenseCAP S700 V2 7-in-1 Compact Weather Sensor
SKU 101991022
S700 7-in-1 Compact Weather Sensor measures air temperature, relative humidity, barometric pressure, light intensity, rainfall (optical), wind speed, and wind direction (ultrasonic). It is ideal for application in a rough environment like the outdoors, agriculture, or smart cities.
Use it with SenseCAP S2100 - LoRaWAN® Data Logger - Seeed Studio or Sensor Hub industrial-grade 4G Data Logger with MODBUS-RTU RS485 protocol - Seeed Studio
JPY¥110634.00
