The mounting bracket is a special designed for SenseCAP ONE weather station. Simply install makes the weather station firmly and stably on the pole or wherever you want to put. It is compatible with the S500/S700/S800/S900/S1000 and whole all-in-one weather station.
The mounting bracket is specially designed for the SenseCAP ONE weather station. Simply install makes the weather station firmly and stable on the pole or wherever you want to put it.
Material | Mounting bracket: Q235 carbon steel; Screw,Nut,Gasket: 304Stainless steel |
Color | White |
Mounting bracket | 1 |
Screw and gaskets | 4 |
| HSCODE | 9031900090 |
| USHSCODE | 9031902100 |
| UPC | |
| EUHSCODE | 9013101000 |
| COO | CHINA |
The mounting bracket is specially designed for the SenseCAP ONE weather station. Simply install makes the weather station firmly and stable on the pole or wherever you want to put it. It is compatible with the S500/S700/S800/S900/S1000 and whole all-in-one weather station.
