おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
WT32-SC01 Plus is a development board for visual touch screen, the board is equipped with GUI platform firmware developed independently, supports graphic drag and drop programming to help users complete the development of customized control platform.It is ideal for implementing smart home.
  • Powerful development firmware: Equipped with GUI platform firmware allows users to customize their own personalized control scheme. Graphical programming makes development easier
  • LCD with capacitive multi-touch panel: RGB colorful display and visual touch operation are more convenient to make interaction
  • Rich extension interfaces: Customize functions such as button operation, voice control, and camera operation through the expansion interfaces
  • Highly integrated MCU: The ESP32-wrever-b MCU is a Wi-Fi + Bluetooth + Bluetooth LE module suitable for various applications. It can be used in low-power sensor networks and important applications
  • Easy to assemble: The small size of the motherboard can be perfectly combined with the user's products through the buckle, saving space and cost
WT32-SC01 Plus is a development board with a visual touch screen. The development system consists of a 3.5-inch LCD screen with a resolution of 320×480 pixels and a capacitive touchpad. It has a feature that supports drag-and-drop graphical programming to help less-experienced users develop solutions.
SC01 plus is an upgraded version of our WT32-SC01 development board. The upgraded product is based on Loxin ESP32-S3. The screen is replaced by IPS and fully fitted, making the touch more sensitive and smooth. At the same time, we are equipped with an integrated black plastic frame, which can be quickly installed on your products by means of clasp. The development board adds a speaker, RS485, SD card and an interface for debugging.
Compared with The previous version of SC01, the main controller of WT32-SC01 Plus development board is configured with a more integrated and powerful WT32-S3-Wrover-N16R2 module. this module is a general-purpose WiFi + BT + BLE MCU module, 16MB SPI flash and 2MB PSRAM configured in. It supports RGB colorful display of various pictures, capacitive multi-touch makes interaction easier, and the use of IPS full touch screen brings users better visual effects and a more comfortable experience.
WT32-SC01 Plus development board can also develop and debug functions such as buttons, voice and camera through the expansion interfaces on both sides, greatly shortening the development cycle of users.
Application
  • Smart Home
  • Environment Monitoring
  • Intelligence Appliance
  • Temperature Controller
  • Home Automation Control
  • IoT Wearable Devices
Specifications
Basic Parameters
MCU
WT32-S3-WROVER-N16R2
Supply Power
DC 5V 2A
Power management
Two LDOS of 3.3V output
Capacity
2Mbyte PSRAM+ 16Mbyte Flash
working current
240mA
Working Temperature
-20°C~70°C
Dimensions
60mm*92mm*10.8mm
Display Parameters
Display Type
LCD
Driver IC Model
ST7701
Viewing Angle
FULL
Display Size
3.5 Inch
Resolution
480*320
Interface
MCU8080 8Bit
Color
RGB565
Touch Parameters
Touchscreen Type
Capacitive touch
Driver IC Model
FT6336U
Interface
I²C
Touchscreen structure
G+F
Touch Mode
Single touch
Hardware Overview
WT32-SC01 Plus
×1
Type-C Cable
×1
認証
HSCODE8517180050
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
A: IPS LCD is popular for embedded UI because it offers wide viewing angles, good color consistency, and smooth screen updates.
A: It uses capacitive multi-touch, enabling smooth interaction such as tapping, dragging, and UI gestures.
A: The screen resolution is 320 × 480 pixels.
A: No. WT32-SC01 Plus uses a backlit IPS LCD, not OLED. OLED is self-emissive, while LCD uses a backlight.
A: WT32-SC01 Plus uses a 3.5-inch IPS LCD with a 320×480 resolution, plus a capacitive touch panel for interactive UI.
WT32-SC01 Plus - ESP32 development board With 3.5 Inch LCD IPS Display Touch Screen
SKU 104990762
WT32-SC01 Plus is a development board for visual touch screen, the board is equipped with GUI platform firmware developed independently, supports graphic drag and drop programming to help users complete the development of customized control platform. It is ideal for implementing smart home.
4.3 Inch LED display
JPY¥4590.00
product.detail.alsoAdd.title
