WT32 4.3 Inch Display is a standard serial port LCD screen, Based on ESP32-S3 and core efficient development platform 8ms(8MS.XYZ), which can quickly help products to complete the application of networking + color screen upgrade.
Now you can experience easy interactions with an ESP32-S3 development board!
It is an ESP32-S3 SoC powered development board with a 4.3 Inch 480*272 RGB interface LCD display. The board is equipped with a graphical user interface (GUI) firmware, which supports graphical drag-and-drop programming and helps users develop a customized control platform.
The 4.3 Inch 480*272 RGB interface LCD screen development board adopts the ESP32-S3 module, which is a general-purpose MCU module with Wi-Fi, Bluetooth, 16MB Flash and 8MB PSRAM.
By using the extended interface on the edge of the development board, developers can customize functions such as button, voice control, and camera, which greatly shortens the user’s development cycle.
The solution is often used in smart products such as bicycle computer meters, energy storage charging equipment, air fryers, water heaters, washing machines, ovens and various applications that come with LCD displays, and is often used as the first choice for upgrading the traditional segment code screen or black and white screen solutions.
Specification |
Details |
SoC |
ESP32-S3 module |
CPU |
Xtensa® dualcore 32bit LX7 microprocessor |
MCU |
WT32-S3-WROVER-N16R8 |
Connectivity |
2.4 GHz WiFi (802.11 b/g/n) and Bluetooth® 5 (LE) module |
Display |
4.3 Inch 480*272 RGB interface LCD display |
Drive IC model |
ST7701 |
Interface |
RGB |
Communication Interface |
RS232/TTL/USB/WIFI/BLE/RS485 |
Power Supply |
DC 5V/1A |
Operating Temperature |
-20 to +70 °C |
Storage Temperature |
-30°C - 80°C |
Operating Humidity |
10% - 90%RH |
Dimensions |
121.92mm*73.15mm*14.43mm |
ESP32-S3 Development board - 1 x 4.3 Inch 480*272 RGB LCD display | ×1 |
USB Type-C cable | ×1 |
| HSCODE | 8531200000 |
| USHSCODE | 8517180050 |
| UPC | |
| EUHSCODE | 8543709099 |
| COO | CHINA |
