製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Super Boost AI Performance: Supports Orin Nano and Orin NX module, delivering up to 157 TOPS, ideal for demanding applications like vision AI, robotics, and generative AI.
  • Energy-Efficient Operation: Configurable power modes from 10W to 40W allow for optimized performance and energy consumption.
  • Robust Thermal Design: Operates reliably in temperatures from -20°C to 60°C at 40W, and up to 65°C at 25W.
  • Rich interfaces: Features 2x RJ45, SIM card, 4x USB 3.2, HDMI 2.1 and CAN. Also including M.2 Key E/M, Mini-PCIe, 4x Mipi-CSI for connectivity and cameras.
  • Ready for Deployment: Supports AI frameworks like NVIDIA Isaac, Hugging Face, and ROS2/1, enabling rapid development of various AI applications.
Jetson Orin Nano / Orin NX Modules Performance with Super Mode
  • Memory Bandwidth Upgrade
  • Higher Throughput
  • Improved higher frame rate processing
  • Enhanced Power Management
  • Reduced Inference Latency
Built for developers, the reComputer Super J401 is an enhanced upgrade over the reComputer J401. It takes edge AI development further with key enhancements: dual GbE (RJ45) ports, LTE, 4x Mipi-CSI for Camera, and full support for MAXN Mode.
仕様
Carrier Board
Storage
1x M.2 KEY M PCIe for SSD
Networking
M.2 KEY E
1x M.2 Key E for WiFi/Bluetooth module
Mini PCIe
1x mini-PCIe for LTE 4G module
Ethernet
2x RJ45 Gigabit Ethernet
I/O
USB
4x USB 3.2 Type-A (5Gbps);
1x USB 2.0 Type-C (Device Mode/Debug);
Camera
4x mipi CSI(2-lane 15-Pin)
CAN
1 x CAN(4-Pin Header)
Display
1x HDMI 2.1
Fan
1x 4-Pin 1.25mm Fan Connector (5V PWM)
1x 4-Pin 2.54mm Fan Connector (12V PWM)
Extension Port
1x 40-Pin extension header
1x 12-Pin control and UART header
RTC
1x RTC 2-pin
1x RTC Socket
LED
2x LED(PWR and ACT)
Button
1x PWR
1x RESET
Switch
1x REC
Power
12-19V 5525 Barrel DC Jack
Mechanical
Dimensions (W x D x H)
71mm x 136mm x 8.5mm
Weight
155.8g
Installation
Desk(Copper column include)
Operating Temperature
-20℃~65℃(25W Mode)
-20℃~60℃(MAXN Mode)
Warranty
2 Years
Certification
RoHS,REACH,CE,FCC,KC
ハードウェア概要
用途
Designed for Developers — Out-of-the-Box Experience:
Whether you're an experienced developer or a complete beginner for embedded AI/GPU inference, use reComputer Super AI box as your first AI workstation, together diving into NVIDIA Jetson for Beginners — your fast track to vision AI, Generative AI, and robotics development! Through these tutorials, you will learn:
  • From Zero to Real Projects: Master Linux basics on the Jetson environment to build an end-to-end AI NVR/AMR.
  • Hardware Integration: Tailored for reComputer Jetson devices for a seamless, out-of-the-box experience.
  • Coverage of Cutting-Edge Domains: Deep dive into CV, GenAI, ROS, agentic AI, and TensorRT optimization.
  • Toolchain Mastery: Hands-on tutorials with NVIDIA JetPack SDK, CUDA, DeepStream, PyTorch, and TensorFlow.
To improve the developer experience, Seeed offers reComputer AI Lab — a platform that helps you deploy AI applications with one-click tools and ready-to-use resources. It includes optimized edge AI model demos for CV, LLM, VLM, interactive tutorials, deployment tools, containerized applications, and community projects to speed up development on Jetson.
Seeed Jetson Develop Tool is a desktop client for all developers who are going to use reComputer Jetson device for the very first time. It brings the common bring-up and development workflow into one GUI: firmware flashing, first-boot initialization, device diagnostics, remote development, app deployment, skill-based automation, OTA updates, and community resources. All we provide here is to help you to get started with Seeed reComputer Jetson hardware much more easily and seamlessly.
Ready to build a solution for the real world? We have Jetson-example prepared for you! It offers one-line deployable projects compatible with generative AI large models, including LeRobot, Ollama, Qwen, etc; with computer vision such as Ultraslytics YOLO26. We have configured all environment setups for you to provide a single command deployment of projects, easy to try out/verify if the trending model performance is suitable for your GPU needs and application scenarios.
Designed for Multi-Camera Vision AI:
Powered by the reComputer Super AI box, the system supports up to 4x USB cameras or MIPI-CSI cameras  to create a 360° panoramic vision network. Leveraging the advanced spatial foundation model, it processes multiple real-time video streams simultaneously to deliver accurate depth perception, comprehensive environmental awareness, and real-time blind-spot elimination for safer autonomous operation.
認証
HSCODE8473309000
USHSCODE8473309100
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
Seeed Carrier Board (reComputer Super J401)
x1
SIM Board
x1
M3 Stud
x5
M3 Screw
x5
reComputer Super J401 Carrier Board for Jetson Orin™ Nano/NX in Super Mode
SKU 100090211
The reComputer Super J401 is an open-source, high-performance Edge AI carrier board powered by the Jetson™ Orin™ platform. Delivering up to 157 TOPS in Super MAXN mode (supporting JP7.2), it is engineered to drive advanced AI models and frameworks. reComputer Super J401 supports Orin NX 16GB/8GB and Orin Nano 8GB/4GB modules.
JPY¥25166.00
