製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Super Boost AI Performance: Delivers up to 157 TOPS in MAXN Super Mode, ideal for demanding applications like vision AI, robotics, and generative AI.
  • Energy-Efficient Operation: Configurable power modes from 10W to 40W allow for optimized performance and energy consumption.
  • Robust Thermal Design: Operates reliably in temperatures from -20°C to 50°C at 40W.
  • Rich interfaces: Features 2x RJ45, SIM card, 4x USB 3.2, HDMI 2.1 and CAN. Also including M.2 Key E/M, Mini-PCIe, 4x Mipi-CSI for connectivity and cameras.
  • Ready for Deployment: Pre-installed with JetPack 6.2 (Supports JP7.2) and a 256GB NVMe SSD, supporting AI frameworks like NVIDIA Isaac, Hugging Face, and ROS2/1, enabling rapid development of various AI applications.
Jetson Orin Nano / Orin NX Modules Performance with Super Mode
  • Memory Bandwidth Upgrade
  • Higher Throughput
  • Improved higher frame rate processing
  • Enhanced Power Management
  • Reduced Inference Latency
Built for developers, the reComputer Super J401 is an enhanced upgrade over the reComputer J401. It takes edge AI development further with key enhancements: dual GbE (RJ45) ports, LTE, 4x Mipi-CSI for Camera, and full support for MAXN Mode.
仕様
Jetson Orin NX System on Module
 reComputer Super J401 NX Bundle
ModuleJetson Orin NX 16GB
AI Performanceup to 157 TOPS
NVIDIA GPU Cores1024 CUDA Cores with 32 Tensor Cores
GPU Max Frequency1173 MHz
CPU8x A78 2.0 GHz
Memory16GB 128-bit LPDDR5 102.4 GB/s
Video Encoder1x 4K60 (H.265)
3x 4K30 (H.265)
6x 1080p60 (H.265)
12x 1080p30 (H.265)
Video Decoder1x 8K30 (H.265)
2x 4K60 (H.265)
4x 4K30 (H.265)
9x 1080p60 (H.265)
18x 1080p30 (H.265)
Module Power10W | 15W |25W |40W
Carrier Board
Storage1x M.2 KEY M PCIe for SSD(M.2 NVMe 2280 SSD 256G included)
NetworkingM.2 KEY E1x M.2 Key E (WiFi/BT combo module included)
Mini PCIe1x mini-PCIe for LTE 4G module(no included)
Ethernet2x RJ45 Gigabit Ethernet
I/OUSB4x USB 3.2 Type-A (5Gbps)
1x USB 2.0 Type-C (Device Mode/Debug)
Camera4x mipi CSI(2-lane 15-Pin)
CAN1 x CAN(4-Pin Header)
Display1x HDMI 2.1
Fan1x 4-Pin 1.25mm Fan Connector (5V PWM)
1x 4-Pin 2.54mm Fan Connector (12V PWM)
Extension Port1x 40-Pin extension header
1x 12-Pin control and UART header
RTC1x RTC 2-pin
1x RTC Socket
LED2x LED(PWR and ACT)
Button1x PWR
1x RESET
Switch1x REC
Power12-19V 5525 Barrel DC Jack
MechanicalDimensions (W x D x H)113.2mm x 109mm x 67mm
Weight200g
InstallationDesk(Copper Studs included)
Operating Temperature-20℃~50℃(40W Mode)
Warranty1 Years
CertificationRoHS,CE,FCC
ハードウェア概要
用途
Designed for Developers — Out-of-the-Box Experience:
Whether you're an experienced developer or a complete beginner for embedded AI/GPU inference, use reComputer Super AI box as your first AI workstation, together diving into NVIDIA Jetson for Beginners — your fast track to vision AI, Generative AI, and robotics development! Through these tutorials, you will learn:
  • From Zero to Real Projects: Master Linux basics on the Jetson environment to build an end-to-end AI NVR/AMR.
  • Hardware Integration: Tailored for reComputer Jetson devices for a seamless, out-of-the-box experience.
  • Coverage of Cutting-Edge Domains: Deep dive into CV, GenAI, ROS, agentic AI, and TensorRT optimization.
  • Toolchain Mastery: Hands-on tutorials with NVIDIA JetPack SDK, CUDA, DeepStream, PyTorch, and TensorFlow.
To improve the developer experience, Seeed offers reComputer AI Lab — a platform that helps you deploy AI applications with one-click tools and ready-to-use resources. It includes optimized edge AI model demos for CV, LLM, VLM, interactive tutorials, deployment tools, containerized applications, and community projects to speed up development on Jetson.
Seeed Jetson Develop Tool is a desktop client for all developers who are going to use reComputer Jetson device for the very first time. It brings the common bring-up and development workflow into one GUI: firmware flashing, first-boot initialization, device diagnostics, remote development, app deployment, skill-based automation, OTA updates, and community resources. All we provide here is to help you to get started with Seeed reComputer Jetson hardware much more easily and seamlessly.
Ready to build a solution for the real world? We have Jetson-example prepared for you! It offers one-line deployable projects compatible with generative AI large models, including LeRobot, Ollama, Qwen, etc; with computer vision such as Ultraslytics YOLO26. We have configured all environment setups for you to provide a single command deployment of projects, easy to try out/verify if the trending model performance is suitable for your GPU needs and application scenarios.
Designed for Multi-Camera Vision AI:
Powered by the reComputer Super AI box, the system supports up to 4x USB cameras or MIPI-CSI cameras  to create a 360° panoramic vision network. Leveraging the advanced spatial foundation model, it processes multiple real-time video streams simultaneously to deliver accurate depth perception, comprehensive environmental awareness, and real-time blind-spot elimination for safer autonomous operation.
認証
HSCODE8471504090
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
Seeed Carrier Board (reComputer Super J401)x1
Jetson Orin NX 16GB Modulex1
256GB SSD (System Installed)x1
Heatsink with Fanx1
Wi-Fi/BT combo Modulex1
Wi-Fi Antenna Kitx2
19V-4.74A Power Adapter(Barrel Jack 5.5/2.5mm, Power cord not included)x1
AC Cloverleaf Power Cord - US/EU/CNx3
Copper columnx5
M3 Screwx5
reComputer Super J401 NX Bundle with Jetson Orin™ NX 16GB in Super Mode
SKU 100029661
reComputer Super J401 NX Bundle is an open-source, high-performance Edge AI Developer Kit powered by the Jetson™ Orin™ NX 16GB platform. Delivering up to 157 TOPS in Super MAXN mode (supporting JP7.2), it is engineered to drive advanced AI models and frameworks. Built for rapid development and production, and equipped with a Wi-Fi/BT combo module and a 256GB SSD, the system features a wide operating temperature range (-20°C to 50°C), robust wireless connectivity, and dual Gigabit Ethernet ports.
JPY¥229339.00
