製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note: When using Jetson Nano, the M.2 Key E cannot work.
仕様
Carrier Board
Storage
5x SATA
1x TF_Card slot
Networking
Ethernet
2x Gigabit Ethernet (10/100/1000M)
M.2 KEY E
1x M.2 Key E interfaces
I/O
USB
4x USB 3.0 Type A(integrated USB 2.0)
1x USB 2.0 Type C(support OTG)
Camera
6x MIPI CSI-2
Display
2x HDMI
Fan
2 x Fan(12V/5V),1 x FAN(5V PWM)
Audio
1 x Audio Jack,2 x Microphone, 2 x Speaker(1W)
SPI Bus
1 x SPI Bus(+3.3V Level)
Multifunctional Port
1x System Control
1x Power Control
2x I2C Link(+3.3V I/O)
1x UART(+3.3V Level)
2x GPIO(+3.3V Level)
2x SPI Bus(+3.3V Level)
1x LED State
Power
+13V to +19V DC Input @ 8A
Mechanical (W x D)
170mm x 100mm
Operating Temperature
-25℃~80℃
ハードウェア概要
Recovery mode
To use USB update, you need to enter USB recovery mode. In USB recovery mode, it can update the file system, kernel, boot loader and BCT.
Steps to enter recovery mode:
(1) Turn off the system power, make sure that the power is turned off instead of in standby mode.
(2) Use the USB type-C link line to connect the carrier and the host.
(3) Power on.
(4) Press and hold the recovery key first, then press and hold the power key. When the light is on, release the power key, wait for 2S and release the recovery key. Or in the power-on state, press and hold the reset key and recovery key, release the reset key for 2S and then release the recovery key.
Please follow the steps of the updated manual for a system update. when entering USB recovery mode, the system will not start, and the serial port will not have debugging information output.
Note: Please check out each specific pin description for A205 carrier board in Document part.
用途
Application Fields:
  • Autonomous Mobile Robot (AMR)
  • AI Video Analytics
  • Machine Vision
認証
HSCODE8543909000
USHSCODE8543903500
UPC
EUHSCODE8543709099
COOCHINA
部品リスト
A205 carrier board
x1
Power Adapter 19V/4.74A (MAX 90W) (Power cable not included)
x1
A205 Carrier Board for Jetson Nano/Xavier NX/TX2 NX
SKU 114110048
Jetson A205 is an extension board specifically for NVIDIA Jetson Nano / Xavier NX/TX2 NX. With the powerful NVIDIA controlling module(not included) and its peripheral interfaces such as SATA and CSI camera interfaces, it's good for diverse edge AI applications like automated optical inspection,robotics, drone, 3D modeling, etc, suitable in manufacturing, logistics, retail, agriculture, and other industries.
JPY¥14086.00
¥63152.00
Save ¥49066.00(78%)
