おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
This Aluminum Heatsink offers essential, active, physical, and strong fan air cooling function for Jetson Orin™ NX/Orin™ Nano/Xavier NX modules, to avoid overheating and throttling problems while operating tough computing tasks.
It is designed for continuous deployment. It can be customized to air flow speed through PWM function and supports reComputer J401 board official.
As well-known powerful edge computing modules, Jetson Orin™ NX, Jetson Orin™ Nano, and Jetson Xavier NX are used in high calculation requirement scenarios. That is, it is essential to keep the module temperatures low and this fine-performance, aluminum Heatsink fan will meet your demands.
CANNOT be used on A603 board. Would need extension wire.
Feature
  • Compatible Fan for Jetson: Support Orin NX/Orin Nano/Xavier NX Module
  • Essential for Tough Computing Tasks: Keeps module temperatures low to avoid overheating and throttling
  • Effective thermal management: Design in full aluminum alloy heatsink
  • Convenient Installation: Mounting Holes & Screws Included
  • Customized Air Speed: Utilize PWM to control the fan speed
仕様
Dimension
58mm x 41mm x 17mm
Rated Voltage
5V
Interface
4-Pin (1.25mm)
Pin
Red - Vcc  Black - GND  Yellow - FG  Blue - PWM
ハードウェア概要
用途
Cooling NVIDIA Jetson Orin™ NX/Orin™ Nano/Xavier NX
ドキュメント
認証
HSCODE8414599060
USHSCODE8473305100
UPC
EUHSCODE8414591500
COOCHINA
部品リスト
Aluminum Heatsink
x1
Thermal Pad
x1
Heat Sink holder
x1
Screws
x4
Aluminum Heatsink with Fan for Jetson Orin NX/Orin Nano/Xavier NX Module (reComputer only)
SKU 110991904
This Aluminum Heatsink offers essential, active, physical, and strong fan air cooling function for Jetson Orin™ NX/Orin™ Nano/Xavier NX modules, to avoid overheating and throttling problems while operating tough computing tasks. It can be customized to air flow speed through PWM function and supports reComputer J401 board official.
CANNOT be used on A603 board directly. Would need extension wire.
JPY¥3150.00
product.detail.alsoAdd.title
