Check out our new arrivals!
reComputer Jetson-10-1-H0 built with Jetson Nano Production Module, reComputer Jetson-20 built with Jetson Xavier NX Production Module also includes on-device carrier board and heatsink.
If you’re designing any kind of computing application with the NVIDIA Jetson TX2 NX, you seriously can’t do without a heatsink if you want to avoid overheating problems. While the Jetson TX2 NX is a powerful piece of computing hardware, even basic tasks become slow and difficult without effective heat dissipation, let alone running high-performance applications for prolonged periods of time.
This aluminum heatsink for the NVIDIA Jetson TX2 NX Module is an essential piece of equipment for keeping the TX2 NX module cool, improving both computing performance and reliability under heavy workloads to realize its true potential. It even includes a fan to provide additional cooling through active air flow!
Dimensions: 65mm x 39mm x 17mm
This Aluminium Heatsink for the Jetson TX2 NX Module provides effective cooling for prolonged high-performance computing, with active airflow supplied by an integrated cooling fan.
heatsink.
