Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Note:
The BeagleBadge is currently available for pre-order. All pre-order shipments are estimated to begin on Jun 30, 2026.
Orders will be fulfilled in the sequence they are received, so secure yours today to be among the first to explore its capabilities!
Step into the future of interactive wearables with the BeagleBadge. Visually striking and ready out-of-the-box, its large 4.2-inch e-paper display and intuitive physical controls—including a 4-way joystick and tactile buttons—offer a dynamic user interface for everything from digital event badges to portable data dashboards. Combined with built-in sensors for tracking motion (IMU) and ambient light, it enables deeply context-aware interactions. Under the hood, the high-performance yet low-power TI AM62L32 processor and comprehensive wireless suite (Wi-Fi 6, Bluetooth 5.2, LoRaWAN) ensure you have the computing and connectivity muscle to run complex edge computing or decentralized communication projects anywhere you go.
  • Prominent e-Paper Display & Intuitive UI
Designed as the ultimate smart badge, it features supports for a large 4.2" e-paper display via an FPC connector for crisp, low-power visualization. Combined with a 4-way joystick, tactile buttons, an RGB LED, and dual 7-segment displays, it offers a fully interactive out-of-the-box HMI experience.
  • Next-Gen Processing Power
Powered by the TI AM62L32, a low-power SoC featuring a Dual-core Arm® Cortex®-A53 processor at 1.25GHz, perfectly optimized for complex edge computing and portable applications.
  • Comprehensive Wireless Connectivity
Integrates the BeagleMod CC3301-1216 module for robust Wi-Fi 6 (2.4GHz) and Bluetooth 5.2, plus a Wio SX1262 module for long-range LoRaWAN communication, ensuring you stay connected anywhere.
  • Rich Sensing & Limitless Expansion
Comes equipped with an onboard IMU and ambient light sensor for context awareness. Designed for ultimate modularity, it features built-in Grove, dual QWIIC, and mikroBUS connectors, granting plug-and-play access to thousands of external modules.
  • Robust Open-Source Ecosystem
Supports Linux and Zephyr base ports with a mainline roadmap. Ready for interactive display development with LVGL and MicroPython libraries, and includes Meshtastic and ActivityPub integration for seamless off-grid messaging.
Category
Item
Processor
SoC
TI AM62L32(Low-power SoC for IOT, HMI)
CPU Architecture
Dual-core Arm® Cortex®-A53 @1.25GHz
Memory
RAM
2GB (128M x 16bit)-1600MHz 3200Mbps LPDDR4
Storage
eMMC
4GB eMMC
Flash
256Mb OSPI flash
EEPROM
32Kb EEPROM
WiFi & Bluetooth
WiFi 6 (2.4GHz) & Bluetooth 5.2 - via BeagleMod CC3301 (MHF4 Connector)
LoRaWAN
LoRaWAN - via Wio SX1262
(u.FL Connector)
On Board
Display
 4.2" e-paper (With 24-pin FPC Connector)
1x MIPI DSI connector for LCD
Sensors
1x IMU Sensor
1x Ambient light sensor
1x Temperature & Humidity sensor (Unpopulated)
Ecosystem Ports
1x MikroBus Connector
1x Grove Connector
2x QWIIC Connector
External Ports
1x USB 2.0 Type-A host
1x Micro-SD socket
User Interface
Buttons
1x Reset buttons
2x Tactile buttons (Back/Select)
Joystick
1x 4-way Joystick (with press)
Output
1x Passive Buzzer
Indicators
1x RGB status LED
2x 7-segment LED displays
Power Input
Interface
1x USB Type-C (Power & Debug)
1x BAT Connector for BL-5C (with fuel gauge monitoring)
Software
Supported Platforms
Linux
Zephyr RTOS
LVGL
MicroPython
Meshtastic&ActivityPub
Hardware Overview
Front
Back
Application
  • Smart Wearables & Smart Badges:Utilizing the ePaper display and sensing capabilities for dynamic event badges or personal assistants.
  • Edge Computing Devices: Leveraging the high-performance TI AM62L32 processor and Linux capabilities to process sensor data locally at the edge, reducing latency and cloud dependency.
  • Off-grid Communication Nodes:Leveraging Meshtastic and LoRaWAN for decentralized messaging in remote areas.
  • Environmental & Health Monitoring:Using the built-in LUX/IMU sensors combined with external bio-sensors via expansion ports.
  • Embedded control systems:Taking advantage of the TI AM62L32 processor's real-time processing capabilities.
Certification
HSCODE8471504090
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
BeagleBadge
x1
BeagleBadge
SKU 100061953
The BeagleBoard® BeagleBadge is a high-performance, fully programmable, open-source smart-wearable development board in a badge form factor. Powered by the low-power TI AM62L32 SoC, it includes a 4.2-inch ePaper display via a 24-pin FPC connector, and includes onboard sensing (IMU, ambient light, temperature & humidity) plus intuitive physical controls. With Wi-Fi 6, Bluetooth® 5.2, and LoRaWAN connectivity—and Grove/Qwiic/mikroBUS expansion—it’s a versatile platform for interactive IoT, event badges, and portable human–machine interface (HMI) prototypes.
JPY¥15670.00
